Battery draining
Old Jan 17, 2018 | 01:46 PM
Tannerj's Avatar
Default Battery draining
Been having an issue with my 09 h3t's battery draining. Noticed the little light next to the CD player turns on even with the key off and CD player makes noise. Tried pulling the CD player to see if anything was stuck in it. Player was empty. Also will not load discs into it(6 disc radio)
Old Jan 17, 2018 | 01:48 PM
Tannerj's Avatar
also it is only taking 12 hrs to drain the battery
Old Jan 17, 2018 | 02:05 PM
Hiro's Avatar
Could be the alternator? My H2 started draining rapidly while I was on a road trip, tried replacing the 6 year old battery and that still didn’t work.Had to replace the alternator, then all was good!
Old Jan 17, 2018 | 02:06 PM
Hiro's Avatar
Also, another post on this forum mentioned that it could be Onstar or other electrical components draining your battery even when the vehicle is off
Old Jan 17, 2018 | 07:21 PM
Tannerj's Avatar
not the alternator... had it tested. Also recently replaced battery. I noticed the red light next to the CD player staying on at all times. I pulled fuse #13 (radio) problem has gone away seems to be related to that. Any other suggestions?
Old Jan 17, 2018 | 07:23 PM
Tannerj's Avatar
How would I disconnect the instant. I don't use it.
Old Jan 18, 2018 | 07:35 AM
Make sure all of the door pin switches are operational. Retained Accessory Power (RAP) will not shut the radio and accessories off if you have a faulty pin switch.
It is possible the ignition switch is not shutting down the accessory power.
That RED light is a security light on the radio.
Old Jan 24, 2018 | 06:48 PM
Tannerj's Avatar
Update: found that the carriage on the CD player was messed up... bought new aftermarket head unit and wireing harness changed it out myself and problem has gone away.
Old Jan 25, 2018 | 06:22 AM
Thanks for posting your fix! Glad it worked out for you.
Norseman
Nov 30, 2017 05:56 PM
John Weaver
Jun 20, 2013 01:18 PM
Champ53
Jul 19, 2011 02:26 PM
syphon
Jan 2, 2008 01:26 PM
brachilius
Jul 17, 2006 11:28 PM
