wont stay in 4wd
I saw this post and immediately knew it's an 06.
Your plastic shift fork is broken.
The code it throw's is:
"Ok, finally got my truck to kick out of 4w high lock, by backing up and turning the wheel in neutral, but now it will not stay in 4wd, after hitting a small bump in the road, it kicks back into 4 wheel high lock"
When this happens it is almost always the fork or the hub/ sleeve, could be other stuff naturally. They are all mostly the same.
"The lock sleeve must move,by itself? No fork,broken fork.
Bad wires could not activate the motor unless told to by the control"
The fork runs in a groove in the lock sleeve. If the fork is good,the sleeve must have lost part of the groove. We would love to see the bad part pictures. The sleeve locks the main shaft to the front drive chain gear. Iwould insist on a new fork.
Hi there !!! I have a similar problem ,When I turn the key to ignition on mi h2 05 don't, the lights of the 4x4 buttons don't stay on ... They turn on just for a few seconds and then turn of ... The control traction and the suspension buttons too,, they dont respond at all ... I was trying to get the reverse light In the stirrup , to turn up a reverse camera ... Was no short cuts , I did it with a led tester .. In some wires I noted , some windows roll up just with testing it ... Hope yo can help me !!!!! Please ...
ReadyGun
12-09-2013 03:23 PM
Hummer79
01-01-2013 04:59 PM
intogaming
10-28-2011 12:30 PM
Sundrop Addict
16
03-02-2010 08:41 AM
