Won't Start
Won't Start
Have a '07 H3 for about 30 days. Sometimes it will not start. Give it 30 minutes and it starts. The security light flashes when it won't start. Have had the brains reinstalled and the starter switch replaced. Anyone have this problem and a possible fix?
RE: Won't Start
Never had that problem, take it to the dealership, they are awesome, Hummer of West Covina is the place to go in Southern California, they always take care of me - they even gave me a free wallet key, free tune up service, and free car wash.
Nothing in its price range can touch it -
RE: Won't Start
Security light in the dash board, on the lower right. The light looks like a lock witha car behind it. It is there to tell you that the security system is operable or not. The switch is a magnetic switch which runs on a small dc current that when you insert the key it reads a change in magnetic resistance and then allows you to start the truck.
Did not have an extra key made, those dont work very well. best off if you purchase a key from the dealership.
I thought this was a forum to exchange answers to common problems and not a social club. sounds like I need answers from someone more technical than Hummer Guy
RE: Won't Start
It sounds like the dealer that replaced your computer in your H3 did not do a security re-learn process correctly. You need to take it back so they can reprogram the PCM the correct way. That's why it isn't starting.
RE: Won't Start
ORIGINAL: wilesrh
To try and help you further with your problem, the fact that you are talking about an '07 H3 (which I also have) means that this issue may be a newer one, and the fact that nobody else has brought it up on this site (try the search function) means that it must not really be that common. I am also assuming from your post, that as the security light is a component of the Passlock system, and the fact that it is always on when you have this problem, probably means that the two are related. You say you have had the "brains replaced" (PCM reprogrammed/reflashed is more recognizable term), and the ignition swith replaced, so obviously your dealer has made some attempt to remedy.
IMO, this is a fairly serious issue as you describe it. If a vehicle will not start reliably, itis extremely inconvenient, and even poses a safety risk to you and others. The fact that this is a new car makes it even less acceptable. I think the general concensus here would be that you should contactyour dealer again, and demand that they resolve this for you in a timely manner. Don't be afraid to pressure them, you paid for the warranty. Maybe you can squeeze out a free loaner, or get them to throw in some free maintenance or goodies for your trouble. If this isan issue other Hummer owners need to be aware of, or even if the fix turns out to be simple, members on this forum will bethankful for any updates you have.
Good luck.
