Wire Colors for Subwoofer
I'm installing a subwoofer in my '08 H3 Alpha, and I need to get the wire colors for the subwoofer audio signal that run through the left side panels that run under the door. I have the power wire, ground, amp turn-on wire, and everything working properly, except for the audio signal. I used the left rear door signal, but that ended up not going anywhere below 40hz. Please help me out.
Thanks, when you get home, could you check, that would be VERY helpful. I don't want to take apart the wheel well to get the signal from the sub itself, because that is too much work and I would probably break all the clips.
if u have a subwoofer u have a monsoon system right?
the sub is connected direct to the amp in the fender area. if you r replacing a sub you need to...replace the sub!! i dont know what else u can do!
if u dont have a sub, u dont have wires for a sub
Brent Whitfield
02-12-2014 06:40 PM
jasontag
04-26-2010 10:08 AM
mushyizcool
19
02-12-2008 08:26 PM
