Window switches
Hello, I've seen several issues on here but none mentioned like this. I have a 07 h3 and the master switch for the passenger window failed only with that one window, I replaced it and now nether switch will power the passenger window. I removed the door panel and jumped the power to the motor to raise the glass back up so I know the motor works. I didn't get any reading on my meter form any activity with rather switch. I also tried swapping the old master back as the pass. Door switch worked before but to no avail. anyone have any thoughts on this ? I just purchase my h3 last week and I love it even with the grimlins. This has been a great resource for me and in my decision to purchase my new ride. thanks so much -Rick |
Are you still using the OEM Crappy Azzed Battery Terminal Connectors?
If you have been using HF for a resource, then you would have seen the first mod for every H3/H3T is to hack off the OEM Battery Terminal Connectors and replace them with a quality aftermarket set, like Stingers, or your favorite brand. Welcome to HF. |
Hi, yes, I did replace them fist thing as they were caked in corrosion. |
Doc, I owe you an apology for being an asshat to you the other morning. I am sorry, I value all of your input and I have been following your advice from day one on this forum and I hope that you will continue to give me your input and advice. I also want to thank you for said advice directly and indirectly. Rick |
Originally Posted by Taneo22
(Post 354504)
Doc, I owe you an apology for being an asshat to you the other morning. I am sorry, I value all of your input and I have been following your advice from day one on this forum and I hope that you will continue to give me your input and advice. I also want to thank you for said advice directly and indirectly. Rick Enjoy the forums. |
Update So, after double checking the switches were the problem, i sourced a matched set from a salvage yard and they work great. I would like to get the later 07 for panels with the switches moved up to the 45 position. the ones they had were not so nice. any way one more grimlin down. R- |
