Will this work? 325/60/18's
Old 12-22-2011, 11:49 PM
TXsk8r's Avatar
Exclamation Will this work? 325/60/18's
Hey, I'm new here and need some help.
I'm planning on cranking the torsion bolts for a level ride next weekend. I need to know if 325/60/18 nitto terra's on 18'' eagle alloy wheels will fit. Im not concerned about the hieght as much as I am with the width (12.83''). Will I need spacers or will they work without? Im fine with a little rubbing at full lock, how much would these rub?
I've searched for a couple hrs now and cant find any answers from older posts.
Old 12-23-2011, 05:40 AM
Bunger's Avatar
You need to be more concerned with the wheels than the tire size.
You need to choose the correct offset & backspacing, and don't forget that H3 wheels are hub centric NOT lug centric, so the center bore must be the correct size.
I really can't help you with what those numbers should be. I prefer the OEM wheels and never had to figure it all out. Others should chime in.
I am not a fan of spacers either.
Old 12-23-2011, 10:10 AM
Until cruising the forums I was never aware so many peeps in TX (you know the manly AMERICAN Lone Star state) were so fond of rice rubber?
Old 12-24-2011, 08:52 PM
blaud87's Avatar
I have 325/65/18s on 18x9 rockstars with 5" backspacing and they fit fine.
Old 12-26-2011, 11:12 PM
TXsk8r's Avatar
sweet, just trying to make sure i wont need any extra parts since i already have the wheels and tires. i got some new shocks on the way that are 2'' longer than the factory ones.
thanks for the help guys
WOLFGANGSTA
63
10-17-2012 08:47 AM
chve8817
02-15-2008 04:30 PM
adamkn
06-17-2007 04:23 AM
kcobra98
08-19-2006 10:24 PM
Stealthhawaii
03-19-2006 02:12 AM
Quick Reply: Will this work? 325/60/18's
