Will these wheels fit??
Old Apr 25, 2014 | 11:17 PM
Poweraidion's Avatar
Default Will these wheels fit??
Will these fit on a 06 h3? http://m.ebay.com/itm/310901766707?nav=SEARCH
Old Apr 26, 2014 | 06:03 AM
nijoma's Avatar
Default Nice looking
No they will not
Old Apr 26, 2014 | 08:29 AM
Happy Hummer's Avatar
I'm guessing here but -6 Offset 4.25 back space 106.20 bore. Unless I missed something in the spec's on this rim. H3 offset 30 or 38 mm back space 5.5 center bore 100 ish. ...
Chris
Last edited by Happy Hummer; Apr 26, 2014 at 02:32 PM. Reason: info was just screwball. ..lol
Old Apr 26, 2014 | 10:22 AM
Bunger's Avatar
Stock OEM 16" diameter wheel is 7.5" wide, 6x5.5"(6x139.7mm) lug pattern, 101 mm center bore, offset is 30mm, and back spacing is 5.5".
When choosing new wheels you need:
1) 6x5.5" lug pattern
2) 101 mm minimum center bore. (H3's are HUB centric, meaning that the wheels locate on the hub center, which is 100 mm, so you can't go too large on the center bore either)
3) 5.5" MAX backspace, less backspace will make tires stick out more as will wider wheels.
IGNORE offset, as it changes with wheel width. It's not an important number.
Old Apr 26, 2014 | 10:34 AM
My friends told me these will fit but rubbing will be a serious issue, because it's gonna stick out. Is that true? Because I still wanna take it off roading
Old Apr 26, 2014 | 10:48 AM
skeptic's Avatar
Doh! Those are one of the two American Outlaw wheels I picked out for my H2 when I'm ready for new wheels and tires - different size of course.. Point is, go to Discount Tires. Roughly the same price and more options on sizes and such. I don't know if they have a more H3 friendly offset or not, but if you have a local Discount Tire that's friendly and helpful like mine they will mount them and let you drive around the block before you decide if you want to buy them or not. I actually did that with a different wheel on my H3T - had a set mounted as a test, but they stuck out too far to pass UT's strict safety check so I didn't buy them.
Old Apr 26, 2014 | 10:49 AM
Bunger's Avatar
They will mount to your truck but they are going to stick out WAAAY too far.
Expect lots of rubbing issues just on the street, forget offroad.
Old Apr 26, 2014 | 10:55 AM
I found another set I like. Theyre also american outlaws. From what I read these ones should work. Will they? Sorry I'm still new to this and thanks for all the replies
4 New 17x8 5 15 Offset 6x135 American Outlaw Hollywood Black Wheels Rims | eBay
Old Apr 26, 2014 | 12:11 PM
fharmon1's Avatar
Discount Tire is an easy way to find correct wheel
http://www.discounttire.com/dtcs/whe...%7C77449&wd=17
Old Apr 26, 2014 | 02:28 PM
Sorry lol,
No idea where my head was earlier.
Stud size 12x1.5mm
Bolt pattern 6x139.7 mm
Offset 38 mm
Center bore 100 mm
back space 4.5 or 5.5 in inches depending on if you have a rancho lift according to what I was able to find.
chris
