QUESTION ABOUT MY SUNROOF
Old 05-27-2007, 07:13 PM
MRDM1's Avatar
Default QUESTION ABOUT MY SUNROOF
i think my sunroof has an issue do i have to hold the button until it open or just press once and it will go all the way in
i have to press until thesunroof is all the way open thats how it works
Old 05-27-2007, 08:07 PM
Default RE: QUESTION ABOUT MY SUNROOF
Thats normal. If you push it again after its all the way open, it will open a bit more, and then one more time a little more to all the way open. you have to hold the button the whole time.
Old 05-27-2007, 08:10 PM
blackstangs281's Avatar
I don't have to hold mine. 1 push and it opens up 3/4, and another push will open it up all the way.
Old 05-27-2007, 08:48 PM
JM's Avatar
JM
JM is offline
Same here.Go to the dealer, maybe the sun roof lost its default configuration stting.I' am sure he can fix that on the spot
Old 05-27-2007, 08:52 PM
no probs here just have to hold it down at first and then the auto takes over, 2005.
Old 05-27-2007, 09:03 PM
MRDM1's Avatar
THANX guyz
Old 05-27-2007, 10:35 PM
In an earlier thread, I outlined the issue that I had with our sunroofshortly afterpurchasing our H2. Initially the sunroof worked just fine; i.e., depressthe button once to openit and depress the buttononce again toclose it completely. About two months 'post- vehicle purchase',I was thenforced to hold-down the button until it closed all the way, and then eventually, the sunroof would no longer close at all. Although my local Hummer dealer tried reprogramming it, it was later determined that it was in fact 'binding-up' and would actually require the replacement of the entire sunroof unit...under warranty of course. Since then, it has worked flawlessly. [sm=icon_cheers.gif]
Old 05-28-2007, 03:25 AM
ORIGINAL: CDiPrecision
Mine as well. They didn't get the AUTO sunroof featuretill 2005 models!!!
Old 05-28-2007, 04:25 AM
ORIGINAL: HummBob
Old 05-28-2007, 02:53 PM
Muddydawg75's Avatar
What's a sunroof?
Quick Reply: QUESTION ABOUT MY SUNROOF
