where to purchase body control module
Can't locate a replacement BCM to purchase for my 2007 H3....have searched on line but no luck.....any suggestions?
Try Rock Auto.
https://www.rockauto.com/en/catalog/...ule+(bcm),2888 |
Thanks but Out of stock
I can find some for the base model but mine is the luxury version and the part number of the BCM
is not an exact match. I guess the options would make a difference |
Originally Posted by Champion@1956
(Post 375800)
is not an exact match. I guess the options would make a difference They have them in stock, call with any questions... https://www.wholesalegmpartsonline.c.../15845922.html Best of luck. |
Thanks for the help
Cleaned all the plug connections with electrical contact cleaner and the key fobs are now working....who knows how long but we will see...thanks everyone
You can also open BCM case, inspect for water damage, clean it too and conserve with some electrical board preserver.
Not been here for a while. Now I need some info on the BCM. New battery always went dead after sitting 6 hrs. Are so. Could not trace it down so off it goes to the dealer. Dealer called and said BCM was full of water and green corrosion in it. The bad news is it is on back order. They can't find a new one anywhere. Maybe after Jan. I know they are on ebay and other places. $100 are less. When Dealer gets one it's Over a grand. Total is $1400. What to do. I talked to the guy who works on all the Hummers. Said it must be programed. If I can find one on ebay I would have to tow back home and put new one in. Don't have scan tool are knowledge to use it. Is it inside right side kick panel? Maybe I can have him put it back in and drive home? Mine is a 2008 Alpha, Do I get a BCM for that model are will all work? Pic of it and location for sure would help.
| All times are GMT -5. The time now is 02:46 AM. |
