Weird speaker issue...
Well my H3 finally ended up with the heating/ac fan issue. I replaced the wiring harness and the relay. I am not sure it happened then or not, but the drivers door speaker quit working. The rest are still working great. Any ideas if I could have pulled something loose at the fan relay area, or if it is something else. Thanks
CDJ |
I'm thinking that the 2 are unrelated. IF, you removed your radio to access the wiring (which is behind the glove box) then you may have a pin not connected at the back of the radio.
Other than that it might just be that the speakers life was over at almost the same time as your fix. What year H3? How many miles? |
its hard to tell if the tweeter is working but with the rear monsoon amp the door and tweeter are wired separatly.
the regular radio wires the door and tweeter with the same 2 wires. if its monsoon and the tweeter works,the wires are from the rear amp. not up front. if the up front wires are messed up going to the rear,the tweet will be dead too.!! you really need to be looking at the diagram to see this , or just pull it apart and wiggle the connectors! |
I didn't pull the radio. I just basically laid upside down in the passenger seat to do the swap. I was hoping it was unrelated. I figured he speaker just crapped out. It is an 07 H3 with between 70,000-75,000 on the clock.
Not sure if it helps. It is a base model with the plain aim CD PLAYER. This thing is the no frills version. 5-speed,cloth seats,and all of the standard equipment. I am not sure if it has the monsoon system, it doesn't say it anywhere. |
1 Attachment(s)
Originally Posted by CharlieDeltaJuliet
(Post 299561)
CDJ OEM left, Pioneer right Attachment 12650 |
Thank you guys.... Exactly the help I was looking for...
I just had to replace my speakers . all that was working were the tweeters . raido store told me i was lucky to get 5 years out of the cheap moulded speakers gm put in.
I have already called my audio guy he is going to replace them and also tint my windows.
| All times are GMT -5. The time now is 10:37 AM. |
