Use existing front tow hooks to hook to “Blue Ox” or similar systems
#22
Hoff,
Yours is very nice. Question to me is whether the one using the existing tow hook points with easy install is adequate? I’m thinking at this point that I will get the welds beefed up if they’re “poopy” as Happy Hummer warned and go with them. I won’t lose the skid plate then.
#23
The welds are not intended to be continuous, just full plate penetration into the frame ends.
#24
Towing an H3 in neutral on the pavement is hardly the amount of stress placed upon the hooks when dragging one through 2 feet of mud or jerking it off a pile of rock. The hooks were designed on purpose to be heavy duty enough to yank on repeatedly, I would not worry about towing a pavement princess.
#25
Hoff,
#26
yes, I thought about how your setup is mounted so much lower. I’m going to call Demco or perhaps the hitch oem and inquire about this
#28
I just spoke with roadmaster and blue ox and they both told me that the towing and towed hitch points must be within 3 inches of each other in elevation otherwise unusual forces will be introduced. Makes sense and I don’t want funky stuff going on back there at 70 mph down a mountain. Scary thought!!
pretty sure that I can mount my hitch high enough so I’ll be OK. Thanks Hoff and others
kim
kim
#30
You obviously did it up right. I was just commenting on the tow hook to frame integrity. .
