Truck won't turn over
Old 10-16-2011, 03:41 PM
gotafish's Avatar
Default Truck won't turn over
Went to start truck after sitting for two days. Doesn't kick over and start. Battery brand new. Any suggestions??? Never had trouble before.
Old 10-16-2011, 04:43 PM
Recovery21's Avatar
Check your fuses first. Without power, it won't turn over. Do all of the lights come on when you turn the key to the run position?
Old 10-16-2011, 04:46 PM
gotafish's Avatar
Yes everything lights up,dash,all icons,etc,just wont turn over.In Boston,gotta get back to NY
Old 10-16-2011, 04:50 PM
Recovery21's Avatar
Hmmm... I know the feeling of needing to get home being far away. I would start with your ignition fuse to make sure you are getting power to the starter. After you have verified the fuse is okay, check the connection to the starter itself. It may have come loose causing your troubles. If that's not it, I'm not too sure what else to tell you.
Old 10-16-2011, 04:56 PM
gotafish's Avatar
cranks,just doesnt kick in......just smellin gas if i crank too much.....like im just floodin.
Old 10-16-2011, 05:01 PM
gotafish's Avatar
weres ignition fuse?
Recovery21's Avatar
So it IS trying to turn over. Sounds more like a spark issue. You made it sound like it wasn't doing anything. Well at least it's trying to. What kind of air filter are you running? If you have a K&N, a lot of the times the oil will foul out the MAF sensor which will also not allow the truck to start or stay running.
Old 10-16-2011, 05:02 PM
gotafish's Avatar
stock air filter.....
Old 10-16-2011, 05:04 PM
Recovery21's Avatar
Not exactly sure what spot it is but it is in your fuse block under the hood. It's right in front of your battery.
Old 10-16-2011, 05:14 PM
gotafish's Avatar
guess if crankin, its prob not fuse.
Quick Reply: Truck won't turn over
