Transmission help
I was turning onto a road today when all of a sudden my h3 was revving and not moving. I found out my reverse works and my 1st and 2nd gears work but thats it. Anyone had this problem before?
Check fluid level(running @operating temperature) then scan and post the codes.
Everybody that has an Auto Transmission take a dump has had "this problem before".
When was the last time your Trans fluid & filter where changed? Same question for your T Case fluid? When you check the Trans Fluid level, look at the color of the fluid and feel free to post a pic of the color on a white paper towel or cloth. |
