transfer case, transmission & TPS relearn needed
After deciphering your sketchy cryptic question.... if you are asking whether the items in your thread title need some relearn procedure vs simply bolt in..... the answer is they are plug and play, no relearns.
I apologize
I apologize for my hard to understand previous post, just a single mom trying to figure out how the heck to keep a Hummer running, and my explaining is not always the best. i was mostly wanting to know if i should be concerned that their no sounds of 4H Lock engaging when the button is pressed, but the normal clicking going between the other buttons. the relearns I should have researched a little more before bothering the forum with stupid run on stuff. I found a couple relearn procedures and ordered a TCCM. maybe that will help.
Thank you for ur ever so polite response and ur time.
