-   Hummer H3 (https://www.hummerforums.com/forum/hummer-h3-17/)
-   -   Transfer case shuddering after oil change- help pls (https://www.hummerforums.com/forum/hummer-h3-17/transfer-case-shuddering-after-oil-change-help-pls-41924/)
Alibou Sep 23, 2019 05:43 PM
No problems before oil drain of TC
1-drained Tc
2-no debris or metal in old oil just brown no burn smell
3- I checked on the net and found ATF Dexron 6 is ok, so I used Motul 100% syn Dexron 6
4-poured 1.690 qt
5-inverted bottom bolt with top bolt ( I guess they are the same?)
6- no leaks at all since 3 days
7- test drove it for 40 miles no problem
8- wife took it in the morning heavy traffic it started shuddering heavily + unreadable dtc codes on scan gauge
9-stopped the car disconnected battery for 5 minutes.
10-CAR started with no problem
11-drove it for another 30 miles it repeated STEP 8 to 10
What should I do?
Overfilled, under filled, not compatible oil?
I have in the idea of draining it again, measure the exacte amount of oil that was in it (only 70 mile on it) and see if the volume is ok.
Refill with a new oil.
I am lost.
Help is greatly appreciated, it is our daily car ��
bronxteck Sep 23, 2019 06:33 PM
you fill the TC until oil starts spilling from the fill hole. you also might want to check your battery connectors for corrosion.
Alibou Sep 23, 2019 07:14 PM
Ok
Should I switch to dex3 thicker then dex6?
My manual says manuel transmission fluid 88861800
thanks
bronxteck Sep 23, 2019 07:28 PM
Bulletin No.: 04-07-30-037E
Date: April 07, 2011
Subject: Release of DEXRON(R)-VI Automatic Transmission Fluid (ATF)
Models:
2008 and Prior GM Passenger Cars and Light Duty Trucks
2003-2008 HUMMER H2
2006-2008 HUMMER H3
2005-2007 Saturn Relay
2005 and Prior Saturn L-Series
2005-2007 Saturn ION
2005-2008 Saturn VUE with 4T45-E
2005-2008 Saab 9-7X Except 2008 and Prior Chevrolet Aveo, Equinox
Except 2006 and Prior Chevrolet Epica
Except 2007 and Prior Chevrolet Optra
Except 2008 and Prior Pontiac Torrent, Vibe, Wave
Except 2003-2005 Saturn ION with CVT or AF23 Only
Except 1991-2002 Saturn S-Series
Except 2008 and Prior Saturn VUE with CVT, AF33 or 5AT (MJ7/MJ8) Transmission Only
Except 2008 Saturn Astra Attention:
DEXRON(R)-VI Automatic Transmission Fluid (ATF) is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON(R)-III and/or prior DEXRON(R) transmission fluids. Supercede:
This bulletin is being revised to update information. Please discard Corporate Bulletin Number 04-07-30-037D (Section 07 - Transmission/Transaxle). MANUAL TRANSMISSIONS / TRANSFER CASES and POWER STEERING
The content of this bulletin does not apply to manual transmissions or transfer cases. Any vehicle that previously required DEXRON(R)-III for a manual transmission or transfer case should now use P/N 88861800. This fluid is labeled Manual Transmission and Transfer Case Fluid. Some manual transmissions and transfer cases require a different fluid. Appropriate references should be checked when servicing any of these components.
Power Steering Systems should now use P/N 9985010 labeled Power Steering Fluid.
Consult the Parts Catalog, Owner's Manual, or Service Information (SI) for fluid recommendations.
Some of our customers and/or General Motors dealerships/Saturn Retailers may have some concerns with DEXRON(R)-VI and DEXRON(R)-III Automatic Transmission Fluid (ATF) and transmission warranty claims. DEXRON(R)-VI is the only approved fluid for warranty repairs for General Motors transmissions/transaxles requiring DEXRON(R)-III and/or prior DEXRON(R) transmission fluids (except as noted above). Please remember that the clean oil reservoirs of the J-45096 - Flushing and Flow Tester machine should be purged of DEXRON(R)-III and filled with DEXRON(R)-VI for testing, flushing or filling General Motors transmissions/transaxles (except as noted above).
DEXRON(R)-VI can be used in any proportion in past model vehicles equipped with an automatic transmission/transaxle in place of DEXRON(R)-III (i.e. topping off the fluid in the event of a repair or fluid change). DEXRON(R)-VI is also compatible with any former version of DEXRON(R) for use in automatic transmissions/transaxles.
DEXRON(R)-VI ATF
General Motors Powertrain has upgraded to DEXRON(R)-VI ATF with the start of 2006 vehicle production.
Current and prior automatic transmission models that had used DEXRON(R)-III must now only use DEXRON(R)-VI.
All 2006 and future model transmissions that use DEXRON(R)-VI are to be serviced ONLY with DEXRON(R)-VI fluid.
DEXRON(R)-VI is an improvement over DEXRON(R)-III in the following areas:
hummerz Sep 23, 2019 07:33 PM
Alibou Sep 23, 2019 07:37 PM
Thanks for the info but
I couldn't find 88861800 fluid where I am, only DeX 3 and dex 6...
hummerz Sep 23, 2019 07:45 PM
Originally Posted by Alibou (Post 364765)
Ok
thanks
Dexron VI; Full Synthetic
Alibou Sep 23, 2019 07:51 PM
Just found this:
This comes from prior issue (2006) of GM Techlink service news and it may applicable to current models.
Quote:
This information applies to 2007 and prior GM passenger cars and trucks.
Dexron III is being phased out as a product name. It is being renamed Manual Transmission Fluid and carries p/n 88861800 U.S. (88861801 Canada).
If fluid p/n 88861800 U.S. (88861801 Canada) is not yet available when servicing a manual transmission or transfer case, Dexron III can be used in its place.
DO NOT use Dexron VI in place of manual transmission fluid in any manual transmissions or transfer cases that specify Dexron III, as a failure may result.
hummerz Sep 23, 2019 07:51 PM
RockAuto
bronxteck Sep 23, 2019 07:57 PM
i found this reference from GM Techlink
EDIT:
hah i see you found it as well
