Transfer case
i have a 550 hp LS2 in it and don’t think the transfer case would hold up to the power. I know it will bolt to my transmission I got the 4l70e in it now which is set up for the stock transfer case at the moment. I was more less curious on how different the wiring would be
Not sure if the t case control wiring will mate or if the case may need to be clocked to fit.
Good luck.
Why not delete the t case all together? The front diff will never handle that much power either.
Good luck.
You'll be fine with the stock transfercase. There are several guys I know making more power than you and have not come close to damaging the stock transfercase. In my v8 alpha I have exploded a rear axle shaft, front 35 spline stub and fullsize cvs but transfercase is still fine.
