traction indicator
Old Jul 16, 2024 | 01:39 AM
arneljohn's Avatar
Default traction indicator
hi,
i have H3 2006, now the problem is the traction sensor maybe, if the traction showing at the dust board, the power will be low. For the temporary solution I'm doing is to disconnect the battery for a while and connected again. then the problem solved, but after a few days the same issue.
i need your advised guys. thanks
Old Jul 16, 2024 | 08:38 AM
Welcome to HF. MOVED to the H3 section where all H3 Tech questions go. Disconnecting the battery does not "solve" your problem, it just reboots the PCM so that it has to report the problem at the DIC after it sees that the issue is present. Your H3 stores all data for the last 300 ignition cycles, power or no power. If you are still tryin to use the Crappy Azzed OEM Battery connectors, hack them off and replace with a quality aftermarket set like Stingers or your favorite brand. Fist Mod to do to every H3/H3T. Known problem and yes, a poor battery connection can cause your issue.
After you get new quality Battery Terminal Connectors, I would check the T Case Actuator connector, clean it with CRC Electronics Cleaner, then check the wires to to it as far back up the harness as you can follow for compromise.
Old Jul 16, 2024 | 01:55 PM
Get the ABS codes read by a scanner. A good scanner not some "cheepo" that will not read ABS codes.
That will tell you where the fault it.
Old Jul 16, 2024 | 05:02 PM
wpage's Avatar
Most DIC alarms for Traction are a nothing burger.
Heather Knowles
Jan 30, 2023 06:34 PM
H3 Brad
Apr 8, 2013 04:46 PM
fhydro
Dec 6, 2010 01:12 PM
djlimos
Nov 1, 2007 04:03 PM
