Traction Failed Service 4x4 error message?
Old 09-06-2008, 02:44 AM
T REX's Avatar
Default Traction Failed Service 4x4 error message?
Hi All
I was launching a JetSki and after the H3 got its wheel stuck on some rope under the tire and broke it I get the message Traction Failed Service 4x4 error message on tne console?
I have tested all 4 wheel drive options and all seems to be working fine exept there is no traction controll as the computer seems to have disabled it.
Is it possible that the computer system has just got it self confused and that there is no serious damage done??
All opinions would be much appreciated
Thanks All!!!
Old 09-06-2008, 09:02 AM
Default RE: Traction Failed Service 4x4 error message?
Traction Control essentially works off of the anti-lock braking system. Each wheel has a sensor for the system, and a wire runs from the sensor to the anti-lock braking module in conjucntion with the PCM.
If your rope wound around and snagged the sensor wire ....or some part associated with those goodies..... the error message is because that sensor is wacked and it cannot operate on only 3 wheels. Trip to the dealer I think??
Old 09-06-2008, 02:14 PM
For a while back a lot of the 06 models would get this issue..turns out there is a problem in the Transfercase Modulating motor..simple warranty fix.
jrc1282
26
01-06-2018 05:02 PM
mskarenbear
21
01-08-2015 02:30 PM
wpduffey
19
10-02-2014 07:14 AM
Jogi
12-24-2012 08:10 AM
marcomelo20
09-25-2008 02:34 AM
Quick Reply: Traction Failed Service 4x4 error message?
