tire pressure sensor
Here is an interesting one:
my tire pressure idiot light comes on about 10 minutes after I start driving...stays on for about 5 minutes then goes off. checked pressure on all tires.all within specs. This happens just about daily. Anyone have any ideas what else to check? is it possibly a bad sensor? how would I know which tire its in even if it was.....any help appreciated....
When tires are cold the pressure is down slightly, triggering the sensor
After you drive a bit and heat them up the sensor goes off.
I solved my problem by inflating to 38 LB all around and not one false sensor trigger, even in the winter.
38 LBs is nothing to worry about if you're concerned
I had a similar problem.
psych0
09-16-2010 05:35 AM
rappelet
08-04-2009 03:27 PM
HummerGuy
04-13-2008 05:17 PM
jackk frost
02-29-2008 01:50 PM
