-   Hummer H3 (https://www.hummerforums.com/forum/hummer-h3-17/)
-   -   TCM failure, 4x4 indicators out (https://www.hummerforums.com/forum/hummer-h3-17/tcm-failure-4x4-indicators-out-17901/)
felixinh3 Jan 10, 2010 11:35 AM
One day a week ago just jumped in started my 2006 H3 and I have the TCM failed warning and none of the indicator lights on the 4x4 are working. Is there a fuse to these? If so which fuse is it? Otherwise is there another fix to this?
Ryan Graham Jan 10, 2010 11:56 AM
ya I'm sure there's a fuse, but I don't know where. I've heard about bad connections at the transfer case, but haven't experienced any problem like this personally. Try searching this and other forums because I have seen threads before about TCM probs
felixinh3 Jan 10, 2010 12:14 PM
The reason I said maybe fuse is because the day before I had problems with my blower motor and was messing with the fuses and then all of a sudden the next time I drive it boom, the "Traction Control Failure" code comes up.:confused:
felixinh3 Jan 10, 2010 03:11 PM
I will check the transfer case connection any other suggestions?
jonesarelli@gmail.com Sep 17, 2020 09:08 PM
Do you mean thr Transfer Case Control Module TCCM?
Check TCVM fuse 12. I intermittently get Stability System Failure... every time fuse 12 (30amp) is blown.
jonesarelli@gmail.com Sep 17, 2020 09:09 PM
Check TCCM fuse 12. I intermittently get Stability System Failure... every time fuse 12 (30amp) is blown.
Doc Olds Sep 18, 2020 10:58 AM
Please DISCONTINUE digging up OLD Threads... READ: Old Threads/'Necro-Bumping'
