TCM failure, 4x4 indicators out
Old Jan 10, 2010 | 11:35 AM
felixinh3's Avatar
Default TCM failure, 4x4 indicators out
One day a week ago just jumped in started my 2006 H3 and I have the TCM failed warning and none of the indicator lights on the 4x4 are working. Is there a fuse to these? If so which fuse is it? Otherwise is there another fix to this?
Old Jan 10, 2010 | 11:56 AM
Ryan Graham's Avatar
ya I'm sure there's a fuse, but I don't know where. I've heard about bad connections at the transfer case, but haven't experienced any problem like this personally. Try searching this and other forums because I have seen threads before about TCM probs
Old Jan 10, 2010 | 12:14 PM
felixinh3's Avatar
The reason I said maybe fuse is because the day before I had problems with my blower motor and was messing with the fuses and then all of a sudden the next time I drive it boom, the "Traction Control Failure" code comes up.
Old Jan 10, 2010 | 03:11 PM
felixinh3's Avatar
I will check the transfer case connection any other suggestions?
Old Sep 17, 2020 | 09:08 PM
jonesarelli@gmail.com's Avatar
Default Do you mean thr Transfer Case Control Module TCCM?
Check TCVM fuse 12. I intermittently get Stability System Failure... every time fuse 12 (30amp) is blown.
Old Sep 17, 2020 | 09:09 PM
Check TCCM fuse 12. I intermittently get Stability System Failure... every time fuse 12 (30amp) is blown.
Old Sep 18, 2020 | 10:58 AM
Please DISCONTINUE digging up OLD Threads... READ: Old Threads/'Necro-Bumping'
BrianDye
Mar 4, 2014 09:35 AM
chazyrae94
Jan 6, 2012 02:47 PM
aiken
Apr 9, 2008 06:11 PM
Burning oil
Dec 15, 2006 02:19 AM
