Super Swampers have arrived!
Old Sep 22, 2007 | 05:37 PM
HUMMER DRIVER's Avatar
Default Super Swampers have arrived!
Well, after a few problems with my order my new wheel set has arrived. Here's some pics of my H3 with the her new shoes.
The tires are Super Swamper Trxus Mud/Terrian 34"x12.5"x16"
The wheels are Pro Comp 1079 Polished Alloy 16"x10".
I like it! Looks a lot better, the ProComp rims are really nice too. Can't wait to get it dirty!
I've not cranked the torsion bars yet, I'll probably lift it an inch or less and level the damn thing from left to right also, the left side is about 1/2" lower than the right w/factory wheels.
Old Sep 22, 2007 | 05:41 PM
Muddydawg75's Avatar
Default RE: Super Swampers have arrived!
Dude..... that is effing awesome....
Nice job....
Old Sep 22, 2007 | 05:53 PM
importkiller's Avatar
looks great and nice tires! Had them on my dually and they are an awesome tire for sure!!! keep an eye on pressures...they will wear scary fast if you run them on low pressure...found that out by experiance[:@]
blackstangs281's Avatar
Looks really good...................nice choiceName:  thumbsup.gif
Old Sep 22, 2007 | 06:40 PM
hilljob26's Avatar
looks great,kinda looks like gunners
Old Sep 22, 2007 | 09:21 PM
hilljob26's Avatar
couple questions,what is the offet on the wheels,and do they rub at all being 10"wheels
Old Sep 22, 2007 | 10:06 PM
SteveO's Avatar
Great choice looks good, will they fit the standard rim?
Old Sep 22, 2007 | 10:10 PM
ORIGINAL: SteveO
you can go to a 35x13 on a stock rim with no problems...but may rub the control arm slightly at full lock depending on the actual tire width...actual sizes and listed sizes are always different.
Old Sep 22, 2007 | 10:16 PM
The wheels have an offset of -24mm. They also have a backspacing of 4.5" and are 16"x10". The wheels stand off pretty far so I think I've got decent clearance on the inside but to be honest I haven't had time to check it out properly, crawling under while the wheels are turned left to right.
They ride really well, a little firmer than my stock wheels but that's OK, they are very quiet on the road too. One bad thing is as wide as the tires are if I drive through any water or whatever liquid it's all over the frikkin Hummer, I'd have to put 4 more inches of fender flare to catch it all.
I don't think these tires are rated for stock 7.5" wheels. I believe the factory specs 8-10 inches. I think some guys have ran big tires on stock rims though, you may do some searching on this forum, it's probably been discussed a time or two before.
Old Sep 22, 2007 | 10:32 PM
HD Ray: looks incredible, excellent, nice!! I like the size selection, sweeeeeet. [sm=smiley20.gif]
