Stab trac control fail?
Old 01-03-2014, 10:02 PM
LouieB!'s Avatar
Default Stab trac control fail?
I've been searching through old posts but can't seem to find this issue alone.
I was driving over a patches of ice on my way home today and when I hit my brakes I just slid. My traction control light came on and said "stab trac control fail service". Every post I came across had this issue in conjunction with the abs light, where mine was just traction light only.
Any ideas? Where to begin?
Old 01-03-2014, 10:15 PM
LouieB!'s Avatar
Looking a little bit more and found this
https://www.hummerforums.com/forum/h...s-codes-10767/
Going to try to cycle from 4/4hi/4lo an then check the tccm and see if that helps.
Old 01-04-2014, 10:48 AM
LouieB!'s Avatar
Well the trac system fail went away but in the process I fount that while alternating between 4/4hi/4lo that it won't lock into 4lo. The light just keeps flashing on it but won't go steady and it won't click in like it did for the others. Also when I hit my rear did lock there is no audible noise or the light won't go steady.
Any ideas?
Old 01-04-2014, 12:23 PM
happythree's Avatar
diff lock is silent but light on. if no lo lock you cant lock diff.
to lock lo you gotta be in neutral huh.
Old 01-04-2014, 01:11 PM
RKSmith163's Avatar
Was your transmission in neutral and were you going less than 3 mph when you tried to go to 4 low?
Old 01-04-2014, 04:33 PM
LouieB!'s Avatar
No I tried it in D,3,2 and 1 all under 10mph
Old 01-04-2014, 04:35 PM
LouieB!'s Avatar
I didn't know that, but I knew the light should stay steady. I didn't try it in neutral though. Just park and all the drives.
Old 01-04-2014, 06:24 PM
RKSmith163's Avatar
All the instructions are in your Owner's Manual. If you don't have one they can be downloaded at hummer.com
Old 01-04-2014, 07:57 PM
LouieB!'s Avatar
Yeah, I found them. Everything works fine now. Just took a little bit.
Old 01-04-2014, 07:58 PM
LouieB!'s Avatar
Thanks everyone for the help.
Shorty
06-23-2015 09:12 AM
mr.spooky
10-25-2013 03:10 PM
Happy Hummer
12-20-2012 12:10 AM
brachilius
28
02-03-2011 08:04 AM
ockie
07-26-2008 06:44 PM
Quick Reply: Stab trac control fail?
