service 4wd
Old Jul 15, 2010 | 08:54 AM
Boominator's Avatar
Post 4WD Error Message
I had the same 4WD error message - a new transfer case shift motor/encoder solved the problem in my case.
Old Jul 15, 2010 | 09:11 PM
2wheelmonster's Avatar
mmmm february
Old Dec 22, 2012 | 05:25 AM
U2flylyn's Avatar
Default Serv 4wd. Light came on. I need used mt 4wd
I never used. 4wd. Light came on any solution. I was told to drive. It. In all a 100. Feet
Old Dec 22, 2012 | 05:27 AM
U2flylyn's Avatar
Default 4wd
The service 4wd. Came. On. I have never use my 4wd drive
Any solution someone said. Drive in 4wd. For 100. FT
Old Dec 22, 2012 | 05:32 AM
U2flylyn's Avatar
Hummer h3
Old Aug 9, 2020 | 09:44 AM
Jessica Bezemek's Avatar
Default 2006 H3, service 4wd
Took Hummer to dealership, they fixed the service 4wd light and bill had been almost $3,000 to fix. Light is back on and having a hard time turning again. Coukd this be the transfer case, or is it something else?
Old Aug 9, 2020 | 11:21 AM
bureau13's Avatar
What did they do to fix it, do you know?
If it's hard to turn, it sounds like you're in 4 Hi Locked. Do the LEDs above those buttons work?
Back when mine was running () I would occasionally get the "Service 4WD" warning but nothing obvious would stop working.
Old Aug 9, 2020 | 11:28 AM
Unfortunately, I do not know exactly what they had fixed. My boyfriend had taken care of it all.
the lights are working. I've switched from 4wd hi to low locked and hi locked, I never hear anything when I switches from one to the other but I just assumed since the lights would change with the selections that obviously it was connected.
Before it had been fixed I could barely turn and would have to accelerate quite a bit to do so. Stopped at the grocery store yesterday after the light has came on a couple times and it's starting to bind again.
just wondering if I should take it back to the same dealer or sell the damn thing.
Old Aug 9, 2020 | 06:57 PM
if they did the work and it is still under there repair warranty take it back. then you know your answer about selling or not
Old Aug 10, 2020 | 10:47 AM
OH Yay!, dug up an OLD AS DIRT THREAD just to ask a question. How about skip the archaeology and fossil dig and just ask your question in a brand new thread?????
ReadyGun
Dec 9, 2013 03:23 PM
intogaming
Oct 28, 2011 12:30 PM
dafihummer
Oct 26, 2011 09:13 AM
Sundrop Addict
16
Mar 2, 2010 08:41 AM
