Scangauge and daystar panel question - Hummer Forums - Enthusiast Forum for Hummer Owners
Go Back  Hummer Forums - Enthusiast Forum for Hummer Owners > Hummer Lineup > Hummer H3
Reload this Page >
Old 06-13-2018, 09:47 PM
Default Scangauge and daystar panel question
I did a search and most posts regarding this are from 2012 and didnít really address my question.
When installing a gauge along with the daystar panel how do I route the cable? Through the plug hole that the daystar sits into?
Thanks in advance!
Old 06-14-2018, 08:31 AM
Broken Halo's Avatar
That's what I did when I mounted my GPS on my Daystar.
Old 06-14-2018, 08:58 AM
Thanks for the reply. Did you use any sort of fish tape to route the cable? Did you drill at all? Iíve tried a couple times with some medium gauge wire just so I can find the path but when I do so it just seems to dead end in all directions.
Old 06-14-2018, 09:04 AM
I don't remember drilling I think I took the center stack trim plate off, then removed the radio to be able to fish the cable through It was several years ago.
Old 06-14-2018, 09:13 AM
Only had to drill a hole through the Daystar for the Scan Gauge wire. Fished that through the dash plug the Daystar hooks into.
Might be easier if you look up from under the dash. Use a flashlight from the top while you look from underneath. It is not a dead end at all, the wire could go many directions. Once you look at what you are doing it should go quick.
On a scale from 1-10, fishing a wire through there is about a 2.
Old 06-14-2018, 12:18 PM
Thanks guys! Iíll try it again tonight when I get home. Last night I stood a flashlight on the hole, beam facing down, and I saw a small amount of light going through but couldnít trace it. With a difficulty rating of 2 I have much more confidence and faith that it should work.
Old 06-14-2018, 01:31 PM
I do not remember exactly, it has been years and I suffer from CRS (Can't Remember Sheet), but you can't go straight down. It is either left/right or maybe toward the radio.
Good luck.
Old 06-15-2018, 11:29 PM
Thanks guys! I got it! I had to curve the wire a bit and point it towards the radio and then over to the left of the vents. Easy peasy after that. I used the wire to fish up the scangauge cable and voila! Thanks again!
06lugnut
08-09-2013 02:29 PM
2010H3T
09-22-2010 05:35 PM
H3FT
General Hummer Talk
11-09-2009 02:52 PM
motley1987
05-18-2009 01:51 PM
White08H3
04-09-2009 10:19 PM
Quick Reply: Scangauge and daystar panel question
Advertising
Featured Sponsors
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
