Remote keyless entry question
well,well, there are separate relays for lock/unlock and the body control module gets involved. its messy. need to get a good look at the door wiring schematic. actually two unlock relays,one for driver,one for all the rest. they all lock together, but unlock separatly.
you can check transmit on the tester at autozone/probably any auto parts store.
ltr:
I cant find it but It seems like the bcm is where the actual remote signal goes first. but I think the problem is in the door logic module. needs resetting. maybe play with the connectors as has been discussed somewhere here. its unlikely both unlock relays went bad.
you really should confirm that the mote actually transmits on unlock.
I have a small frequency meter and it shows activity on lock/unlock. just tried!
ltr:
Hey Hummerz,
Could i ask you last question around this topic:
Is it possible the remote to be fully OK but the problem to be in other thing:
I have all together 3 "parts" on the key - key, remote, and something that looks like a human ring with battery on top.
Not sure what is this device, but I just recall how one of my friends was playing with me he give me the remote - and told me try to open the car, i can't be he can because of that device that have to be close to the door, I will try to change the battery tomorrow and test it do you think that sounds reasonable?
After you replace the battery you have to repeatedly hit lock and unlock until the remote starts working again.. GL
Monday it will come and I will clean the small PCB and will reuse it with the new housing.
But could you advice me what is this defice on the picture (key remote contro and ??????)
a guess, this is only a guess, it looks e it could be, A PART of a key chain flashlight !, the battery end of it. it looks like 2 button batteries.
do they come out? if so, the rest is missing. toss it if this is so.
a guess.
a guess.
By the looks of your unlock button on the keyfob(worn), You definitely need new pad/case. GL
4u33er
11-17-2013 12:32 PM
varun
06-08-2012 05:06 PM
rmoore
12-22-2008 09:36 AM
