Recall and Technical Service Bulletin Titles
Old 11-18-2006, 02:41 PM
cnynctry's Avatar
Default Recall and Technical Service Bulletin Titles
Thought this might help when you take a problem to the dealer and they insist they have never hear of that problem. Supplying them with the TSB number may help get you back on the road faster. to actually see what the TSB says you need to pay for a subscription from this site. http://www.alldata.com/recalls/index.html
Technical Service Bulletin is a notification from the manufacturer to advise on new diagnostic and repair procedures. Also, this TSB may cover known vehicle problems, notifications about new and improved parts, warranty information, or service manual updates.
Automotive Recall and Technical Service Bulletin Titles for 2006 Hummer H3 L5-3.5L VIN 6.
TSB Number & Issue Date TSB Title
05109 MAR 06 Recall - Tire/Loading Label Non-Compliance
06045 JUN 06 Campaign - Mercury Disposal Notice Label Installation
06011 JUN 06 Campaign - Vehicle Jack Replacement
05115 DEC 05 Campaign - Rear Window Washer Pump Inoperative
06-06-01-017 JUN 06 Engine - Cylinder Head Removal & Installation Procedure
06-08-67-008 JUN 06 Body - Roof Rack Rail Cracked/Poor Fit
00-05-22-002H JUN 06 Brakes - Warranty Service Guidelines & Procedures
99-08-51-007C JUN 06 Wheels - Aluminum Wheel Refinishing Recommendations
99-04-20-002D JUN 06 A/T, Drivetrain - Clunk When Shifting Between Gears
06-04-21-002 JUN 06 Drivetrain - Service 4WD Message/DTC's Set/4WD Inop.
06-00-89-029 JUN 06 Interior - Vinyl/Fabric/Leather Cleaning/Restoration
05-06-04-035B MAY 06 Fuel System - E85 Gasoline Usage Precautions
06-08-67-007 MAY 06 Body - Sunroof Rattles When Partially Open
05-08-51-008A MAY 06 Body - Bumps/Rust Colored Spots In The Paint
06-04-21-001 MAY 06 Drivetrain/Electrical - Transfer Case Connector Kit
01-07-30-042D MAY 06 A/T - 2-3/3-2 Shift Clunk Explanation
06-02-35-011 MAY 06 Ignition System - Revised Ignition Switch Replacement
04-06-04-036B MAY 06 Engine Controls - Reprogramming Warranty Coverage
01-04-18-001E MAY 06 4WD/AWD System - Driveline Characteristics
06-08-45-004 MAY 06 Electrical - I/P and General Wiring Harness Repair
00-06-02-006C MAY 06 Cooling System - DEX-COOL®(R) Coolant Usage
06-08-66-007 APR 06 Body - Back Body Opening Plug Loose or Missing
06-08-110-002A APR 06 Accessories - Homelink(R) Installation Information
06-08-44-015 APR 06 Audio System - Portable Audio Equipment Noise
05-03-10-003B APR 06 Wheels/Tires - Slow Air Leaks From Aluminum Wheels
06-08-61-002 APR 06 Body - Revised Tow Hook Replacement Procedure
05-08-64-002B APR 06 Body - Door Latches Freeze in Extreme Cold Conditions
06-01-37-004 MAR 06 A/C - Revised Condenser Replacement Procedure
06-02-32-004 MAR 06 Steering - Revised Steering Gear Replacement Procedure
06-03-06-003 MAR 06 Suspension - Revised Trim Height Inspection Procedure
02-08-48-001B MAR 06 Body/Glass - Urethane Adhesive Usage Recommendations
02-06-03-009B MAR 06 Electrical - Battery Charging Tips
05-06-03-002B MAR 06 Electrical - Battery and Charging System Diagnostics
02-06-04-015A MAR 06 Starting System - Engine No Start/No Crank Condition
05-08-46-008A MAR 06 OnStar(R) - Language Change (Canada Only)
02-08-46-010G MAR 06 OnStar(R) - Programming For Canadian French
06-03-10-004 MAR 06 Wheels/Tires - Wheel Weight Usage & Precautions
06-07-30-007 FEB 06 A/T - Harsh 1-2 Shift/MIL ON/DTC P0894 Set
05-08-46-004A FEB 06 OnStar(R) - Phone Number Incorrect/Assigned w/Diagnosis
01-07-30-036F FEB 06 A/T - 4L60-E, 4L65-E, 4L70-E DTC P0756 Diagnostics
02-06-05-004B FEB 06 Exhaust System - DTC's Set/Catalytic Converter Damage
06-03-07-001 FEB 06 Steering/Suspension - Revised Alignment Specifications
05-08-46-001B FEB 06 OnStar(R) - System Inoperative/
Old 11-18-2006, 04:31 PM
Default RE: Recall and Technical Service Bulletin Titles
I got my h3 in April of 06 and tehy told me today at the dealer that there is no campain for my jack....strange that this list shows it: 06011 JUN 06 Campaign - Vehicle Jack Replacement
Old 11-18-2006, 04:58 PM
ORIGINAL: importkiller
Time to talk to the dealer...ASSH0LES!
Old 11-18-2006, 05:03 PM
I don't know if it was them or not, says right on the paper that they ran my vin and came up with no open campaigns, I can't believe any credible dealer would openly lie about running the vin...maybe I have too much faith in people[&o]
Old 11-18-2006, 05:08 PM
cnynctry's Avatar
Without knowing what VIN numbers that may have been affected, the dealer may be correct for your truck. The issue date is just that. It may not cover all VINs. I'm just guessing at possibilities.
Old 11-18-2006, 06:30 PM
yea, thats what I was thinking. I'll try to call another dealer on Monday and see if they can run my vin for me.
YH2Owner
03-23-2011 01:45 PM
importkiller
03-16-2008 09:09 AM
jen813
10-25-2007 04:05 PM
Sparkplugs.com
12-01-2006 06:19 PM
Dennis
09-18-2006 05:03 PM
Quick Reply: Recall and Technical Service Bulletin Titles
