-   Hummer H3 (https://www.hummerforums.com/forum/hummer-h3-17/)
-   -   rear wiper (https://www.hummerforums.com/forum/hummer-h3-17/rear-wiper-34151/)
ODIMUS Nov 9, 2014 12:40 PM
rear wiper
I'm having a problem with the rear wiper fluid on my 07 H3. I push the button and I can hear the motor working, no lines disconnected, and no leaks. Thiking possible kinked line or clog somewhere or is it possible the motor is going out? The rear wipers work and everything works in the front the way it should. Anyone else have this problem? Thanks!!!
RKSmith163 Nov 10, 2014 07:38 AM
Switch the hoses from each motor to see if they are working. They are easy to get to. They are located on the passenger side top of the firewall. If both are working, then you just have to start looking for an obstruction. The rear washer hose can be accessed by removing the jack cover on the tailgate. Good Luck
norinco3264 Nov 10, 2014 01:53 PM
Check fluid levels.. Had the same exact problem as you. Checked fluid and still had some in the resevoir, but the line to the rear will cut out when it gets low.
When I refilled mine it worked good as new.
CarlosC Nov 12, 2014 12:30 PM
Slightly off topic, but is it normal for the rear wiper to only go about 3/4 of the way across the back window? Any way to have it make a full 180 degree swipe?
RKSmith163 Nov 12, 2014 01:20 PM
Normal. Some have adjusted the home position to make it wipe more of a usable area.
Bunger Nov 12, 2014 01:38 PM
That rear wiper is so small and useless that I have completely removed it from my H3, 3 years ago.
TAINTER Nov 12, 2014 07:44 PM
I have reclocked 4 H3 rear wipers so you get almost a full sweep. The other plus it the the rear defroster heats the wiper to remove ice from the edge of the wiper.
CarlosC Nov 13, 2014 11:21 AM
"I have reclocked 4 H3 rear wipers so you get almost a full sweep."
Tainter - how do you do this?
Doc Olds Nov 13, 2014 01:34 PM
Loosen the wiper motor shaft nut like you were going to remove the arm and rotate the wiper further counterclockwise, then tighten the nut in the new position.
Scouser Nov 13, 2014 02:47 PM
Mine stopped working. It had factory grease in the tube that had gone solid. Cleaned it out and all ok.
