rear wiper
I'm having a problem with the rear wiper fluid on my 07 H3. I push the button and I can hear the motor working, no lines disconnected, and no leaks. Thiking possible kinked line or clog somewhere or is it possible the motor is going out? The rear wipers work and everything works in the front the way it should. Anyone else have this problem? Thanks!!!
Switch the hoses from each motor to see if they are working. They are easy to get to. They are located on the passenger side top of the firewall. If both are working, then you just have to start looking for an obstruction. The rear washer hose can be accessed by removing the jack cover on the tailgate. Good Luck
