Rear turn signal bulbs keep blowing - change to LED?
Old 11-21-2010, 08:06 PM
hearseman's Avatar
Default Rear turn signal bulbs keep blowing - change to LED?
My rear turn signal bulbs keep blowing and was thinking of getting some LED bulbs. I don't really care for getting a new LED housing and I generally don't like how they look anyway. I was thinking that getting some LED bulbs would work but I got some from eBay (Hong Kong) and they don't fit right, although they were sold as 3157s. Has anyone changed to LED bulbs and if so, where did you get them?
Old 11-22-2010, 05:49 AM
Broken Halo's Avatar
I think I would try and resolve the issue with your incandescent bulbs blowing, first. You might have an electrical problem that's going to ruin your expensive led's!
Old 11-22-2010, 07:34 AM
RKSmith163's Avatar
Check your trailer hitch wiring to make sure it is not rubbing the body between the tailgate and the bumper. There are threads on the subject that you should find if you do a searchl\.
Old 11-22-2010, 08:17 AM
bheff's Avatar
One thing you didnt mention is how often your are blowing a bulb. Either way you need to figure out why this happening. Could be as simple as a ground. But you need to figure it out before you attempt new bulbs.
Old 11-24-2010, 05:54 PM
drtom's Avatar
Banned
Default step 1
measure volts, at startup,,then monitor, ive seen over 15 v in gm.
still never saw bulbs burn
Ocx
01-24-2014 02:03 PM
nijoma
12-17-2013 07:54 PM
Chiropastor
08-06-2011 07:43 AM
AMG55
19
01-11-2008 10:03 PM
thehammer12
07-06-2007 10:19 AM
Quick Reply: Rear turn signal bulbs keep blowing - change to LED?
