Rear Defrost
Old 12-09-2013, 11:43 AM
CARdiac's Avatar
Default Rear Defrost
So when I bought my H3 a couple of years ago I asked the dealer to check the rear defrost as it barely worked. They claimed it was fine...at this point I can't get it to remove anything from the window... fogging this morning was bad after I removed the ice but the defrost didn't do anything (can see the wires but no fogging removed past that).
The light on the dash comes on when i push in the button- Any thoughts on where to start looking to fix this?
Old 12-09-2013, 11:45 AM
CARdiac's Avatar
I apologize, I did a search and nothing came up. I see where the same question was posed last year but no-one responded.
Old 12-09-2013, 01:41 PM
Bunger's Avatar
On one of the other forums someone found a loose connector at the defrost grid. If the connection isn't good then maybe it's not getting full power.
Old 12-09-2013, 06:00 PM
happythree's Avatar
you can pull the trim and check for 12v on the heat element/connections.
nickoliboz
11-29-2017 08:49 AM
ddawg187
11-29-2017 08:48 AM
Hooty-Hoo
09-02-2011 11:26 PM
th3_villain
10-07-2009 08:38 AM
lukascrystal
12-27-2008 04:21 PM
Quick Reply: Rear Defrost
