"Real" Adventure package?
Sorry for the newbie question but...
Is there a quick and easy way for to tell if a H3 really has the adventure package? May be buying a H3 @ some point soon. Not that familiar with the breed. Don't want to be faked out by 35" tires and a badge. Something in the vin? May meet up with a seller soon to check one out. Won't have a lot of time &/or resources. |
If it is an Adventure Pkg. it will have Locker switches on your switch panel. 1 switch (rear locker) 2008 and prior, 2 switches (front and rear) 2009 and 2010 models. They will be to the far right of the 4 Hi, 4 Lock, and 4 Low Lock switches. If someone has switched tires, this is the best way to determine this as there is no badging.
Thank you very much.
Knowledge is power. |
I went through this wen I bought mine. As RKSmith163 says - the switches are the only way to tell. If you are looking online, forget about what the ad says - dealers don't seem to know the difference. Almost all "Adventure package" H3s I found were not, and the one I bought was not listed as Adventure or Offroad at all. Once you know what you are looking for and get the hang of it, you can spot the switches (or lack of switches) easily on interior photos. Even poor quality, bad angle shots. You just look for 2 white marks instead of 1 where the switch would be.
1 Attachment(s)
The one light up on the right, with an X in between the rear tires.
Attachment 16479 |
Thanx to all.
This will help me a lot. |
it will also have 285 tires,not 265
Originally Posted by Major Tom
(Post 242815)
The only way to actually know is to check the dash and/or put it in 4lo and lock the rear while on jack stands. I have also seen dealers put a picture of an Adventure/OffRoad dash on a base/lux before also. Tricky bastards, we gotta know our stuff to make sure we get what we want!:D |
Well, I learned something today. Actually, three somethings.
I didn't know that only the Adventure series had the locker switch(es). I didn't know that my '08 locked only the rear diff. I didn't know that the '09 and '10 locked both ends. (Actually, that last one kind of pisses me off) I wonder how tuff it would be to put a front locker on my '08. Thanks Guys |
It can be done. If you have an Alpha you can use the existing case and gears. The 08 Alphas have a Cast Iron front diff. and you want the CI front diff if you are going to be putting a locker in there.
06-08 I5s have an Aluminum case which can "deflect" when under stress from OffRoading. 08 Alphas have the Cast Iron case 09-10 All have the Cast Iron case regardless of engine or Adventure/OffRoad package. |
| All times are GMT -5. The time now is 11:05 PM. |
