Pushing E fan and transmission oil cooler
Hello Hummer enthusiast
The summer the hot weather in my hometown Im facing some humming sound since the temperature 115 f. so im thinking to add additional electric fan infront of my car. i found this fan, is it enough size and do you think that it will deliver the required to drop the temp also my transmission i feel some weakness due to high mileage 150 k. i heard some positive feedback to add a cooler like this product Tru Cool 40K Transmission Cooler Transmission Oil Cooler GVW Max 40,000I need your valuable comments for this https://cimg3.ibsrv.net/gimg/www.hum...d4e373c5f2.png Found this e fan installed in youtube |
I seldom see 115 degree weather in Wisconsin (usa). We do however see -16 degrees.
I'm currently running in stand alone configuration: B&M 70264 SuperCooler Automatic Transmission Cooler
this is the fan i added ebay electric fan and i added this trans cooler both were not that hard to install. if you have the money pcmofNC has a kit with dual fans.
The down side with Pusher Fans is they are out front of the Radiator and when not on, or when on if not sufficient cfm flow, they can impede airflow to the radiator leaving the only net gain to be delivered at low speed or idle. Take that into consideration.
+Pusher fans sends more debris to the condenser/radiator, blocking the fins. https://cimg7.ibsrv.net/gimg/www.hum...c855e3533c.gif
https://cimg0.ibsrv.net/gimg/www.hum...8fde97723f.gif |
(Post 401259)
and does the thermostat relay enough for electrical protection ? |
here it is like living in madmax, often dusty during summer>>
also i just wash it using pressure washer and the engine as well the radiator fins was super dirty >>so i will make it every quarter to clean them as a PM. |
it looks great but im living is saudi arabia the shipment price will be higher than the parts itself:eek:
(Post 401232)
Put an additional radiator on the automatic transmission, move the thermostat up (185-189 F), set the electric fan. Only then will the cooling system work normally.
