Problem
I have a 2006 H3 I pulled into my driveway and it went dead. I put it in park turned the key and I have no power zero.
Welcome to HF. This area is for intros.
Ask your question in the H3 area. Most don't check the New Member Area. |
Welcome. MOVED for you.
Going to need more information.... like recent work done, any recent symptoms before this happened. Until then, let the wild guesses occur. Are you still using the crappy OEM Battery Terminal Connectors??? They are garbage, and should be replaced with a quality aftermarket set like Stingers or your favorite brand. |
Your H3 must have communicated an issue to you before this.
You've neglected your H3, and passed many auto repair shops. Now your H3 is dead at home. Just give your H3 a proper burial. RIP H3 2006-2019 |
(Post 363850)
Are you still using the crappy OEM Battery Terminal Connectors??? They are garbage, and should be replaced with a quality aftermarket set like Stingers or your favorite brand. https://cimg4.ibsrv.net/gimg/www.hum...e3b6d4a5b3.jpg |
Dead battery...
