PCM adjustable chip
Old Sep 24, 2013 | 10:56 PM
byeatts's Avatar
Default PCM adjustable chip
They claim huge Hp gains with an adjustable performance ****. I have a Jet chip now , This adjustable setup sells for 69 bucks and dosnt hook into the modual, it ties into the Mass Air Flow sensor, Anyone try one?
Old Sep 25, 2013 | 08:21 PM
byeatts's Avatar
Well I will try this chip and see if it delivers. I ordered the stage 2 which they say can deliver 60HP." Doubtful". they said i can leave my Jet chip installed and add new setup. What I like was you can dial in performance from the dash. I has more flexibility than the pre set Jet which is tame and set for 89 octane.with the header install, intake system, Magnaflow, jet chip ,lightweight ashtray we will see how she pulls the 35,s.
Old Sep 26, 2013 | 04:44 AM
telemike's Avatar
PCMofNC with HP Tuners is the way to go. The actual PCM is programmed with air/fuel ratios, transmission shift points and can turn off top speed governor and the PASSKEY ignition lock that goes wonky. ALL the chip does is try to fool the PCM with different data than it would normally see to change things. Much better to actually program the PCM IMO
Old Sep 26, 2013 | 08:44 AM
telemike's Avatar
2007-2008 Hummer H3 Performance Module and Chip - Jet, Jet Performance Stage 2 - JCWhitney
$235? and it needs 91 octane?
I paid PCMofNC to program my PCM and they dialed in the programming specifically for my H3 by test driving and adjusting parameters until it ran real good for $199.
MartyMcflyest
Sep 2, 2014 06:54 PM
coldhammer
Apr 24, 2014 12:06 AM
mfish
Jul 13, 2007 08:18 PM
bogy
Aug 21, 2006 08:31 PM
madmaxmyers
Jul 23, 2006 12:17 PM
