P0300 and P0128
Old 01-10-2013, 06:39 AM
Matthew C. Powell's Avatar
Originally Posted by qui
I notice the same issue with the lights dimming and AC/heater running lower while braking, but I don't have any codes or a check engine light, and I'm not idling rough or having trouble starting. Are we likely experiencing the same issue?
I'm not really an expert when it comes to this, but I would say your issue is about the same... My idle was not really bad... Starting the engine up was fine too. The headlights and heater bogging down when stopping was a problem. I assume that cleaning the MAF and throttle body would really help your issue. It did mine even though I was showing codes as opposed to you not having any. Hopefully someone with more experience will chime in.
Cheers,
Matt
Old 05-01-2013, 09:49 AM
06redhummer's Avatar
I replaced my thermostat once the code P0128 came up and still engine light comes on. So I did the steps on this site H3 Throttle body and MAF sensor cleaning (up to step 5 (I couldnt get the vacuum hose on the intake loose so I left it as is) to clean the MAF sensor, and now I get different codes.(P0449) Would these codes have anything to do with messing with this vacuum hose or other sensors? TIA
Old 05-01-2013, 01:06 PM
Xlr8n's Avatar
A quick search of the forum database would have revealed to you a few possibilities that could be related to your recent maintenance: https://www.hummerforums.com/forum/h...de-help-14854/
Otherwise, inspect the evap. solenoid in question. They are known to crack and erode surrounding the attached breather port.
BERULAKIDE
06-25-2014 07:12 PM
norinco3264
20
04-25-2014 05:51 PM
tekstyle
10-21-2013 02:15 AM
ericksos
01-05-2012 02:12 PM
giant H2
09-28-2009 05:14 PM
Quick Reply: P0300 and P0128
