Oil change per DIC
Old Dec 10, 2011 | 07:24 AM
Widespread Hummer's Avatar
Default Oil change per DIC
Been waiting for my DIC to tell me its time to change my oil. And waiting, and waiting, and waiting.... Its driving me nuts. Its been about 9k since my last oil change. Does everyone wait until the DIC indicator pops up or do it when you feel its time?
Old Dec 10, 2011 | 07:27 AM
Broken Halo's Avatar
I have faith in the technology.....I wait. BUT...I only use synthetic oil
Old Dec 10, 2011 | 07:48 AM
WannaScoopaDis's Avatar
As often as you hear about sensors and computers going bad, I would not wait. Its not worth the $20 to change my oil to wait and see what happens if I didnt. Im sure the consequences would cost a whole lot more... Just my $.02
Old Dec 10, 2011 | 07:54 AM
Yes synthetic here as well, and the oil doesn't look particualrly dirty, not that that is a defining test. I guess I just have to learn to trust tech myself
Old Dec 10, 2011 | 08:07 AM
RGray711's Avatar
I also use synthetic but I don't wait about 6000 I change.
Old Dec 10, 2011 | 10:36 AM
mgoblue85's Avatar
Synthetic here too. And around 6000 or so miles. 9000 seems like a lot to me.
Old Dec 10, 2011 | 01:06 PM
wfturner's Avatar
Wait, do I hear your DIC chiming ??
No I don't, and yes to synthetic oil and get it changed.
Why wait ?
Besides all the guys answers just above can't be all wrong
Old Dec 10, 2011 | 01:44 PM
No I don't, switch to synthetic oil and get it changed.
Why wait ?
If that's what you're comfortable with, then go for it......your money, your truck. But the old 3000 mile rule has gone the way of the carburetor. Today's engines and lubricants far exceed the quality and technology of years past. The owner's manual DOES have a disclaimer stating to change at least once a year even if the Oil Life Indicator doesn't activate. An article worth reading:
Is the 3,000-Mile Oil Change a Thing of the Past?
Old Dec 10, 2011 | 01:52 PM
Yep, I change my own oil (Mobil 1) and always wait for the DIC to tell me when it is time. Usually amounts to somewhere around 7500 - 8000 miles.
The GM Oil Life Monitor uses NO sensors, and its program is set for mineral based oil (except for the Corvette which requires synthetic). So if you go by the monitor, and use synthetic, you have built in your own extra protection buffer.
GMs FAQ:
Frequently Asked Questions
How does the system work?
The GM Oil Life Monitor System is not a mileage counter. It is actually a computer based software algorithm that determines when to change oil based on engine operating conditions. There is no actual oil condition sensor. Rather, the computer continuously monitors engine-operating conditions to determine when to change oil. Over the years, millions of test miles have been accumulated to calibrate the system for a variety of vehicles. The system was first introduced in 1988 and is now on more than 10 million
GM vehicles.
How do I operate the system?
The GM Oil Life Monitor System is very easy to use. First, refer to the vehicle owner’s manual for a description of the specific ‘change oil’ message and the instructions for resetting the system. When the vehicle has been driven the appropriate miles, the ‘change oil’ message will be illuminated on the instrument panel or driver information center when the vehicle is first started. An oil change should be done within two fuel tank fillups
from when the message was first displayed. Immediately after the oil has been changed, the system must be reset. After resetting, the ‘change oil’ display will no longer be displayed after engine start up.
I change my oil every 3000 miles, so of what use is this system?
You can continue to change your oil every 3000 miles if you so choose, but remember to reset the system after changing the oil or you will get a false “change oil” message. However the GM Oil Life Monitor System will allow you the ability to extend the mileage between changes without harming your engine. This will save you time and money as well as helping to protect the environment by minimizing the amount of used oil.
Do I have to use special oil?
The GM Oil Life Monitor System is calibrated for use with standard “Starburst” mineralbased automotive engine oil. Synthetic oils are not required except for the Corvette. Make sure to read the owner’s manual and select the viscosity and oil grade that is correct for your engine. Any oil selected for use should carry the ILSAC “Starburst”.
How many miles can I expect to go between oil changes when using this system?
The beauty of the GM Oil Life Monitor System is that it will automatically
adjust the oil change interval based engine characteristics, driving habits and the climate in which the vehicle is operated. For instance, mild highway driving in a warm climate will maximize the interval between oil changes. Depending on the vehicle, this could be in excess of 7000 miles and as high as 12,000 miles. On the other hand, short trip driving in cold a climate may limit the oil change to 3000 miles or less. In general, most people that drive
a combination of city and highway schedules find that the GM Oil Life Monitor System will indicate an oil change every 7500 to 8500 miles.
What happens if I change oil and forget to reset the system?
Since the GM Oil Life Monitor System does not actually sense oil condition, it is important that the engine computer knows when an oil change takes place. By enabling the reset (read owner’s manual for instructions), it lets the computer know an oil change has taken place. In the event that an oil change is done without resetting the system, the ‘change oil’ indicator will remain illuminated until the system is rest. The more miles that are driven without the system being reset, the more inaccurate the GM Oil Life Monitor
System will be. If more than 500 miles have been driven after an oil change without resetting the GM Oil Life Monitor System, the oil change interval should be defaulted back to 3000 miles. After the oil has been changed and the system reset, normal use of the system can be resumed.
The oil change service station recommends that I change oil every 3000 miles. Why should I not believe them?
The 3000 mile oil change is very conservative approach to maintaining your vehicle that dates back to 1968. Many advancements in engine and oil technology have been made since then. These advancements, in conjunction with using the GM Oil Life Monitor System, allow engine oil drain intervals to be increased without risking harm your the engine.
I change my own oil, should I reset the system myself?
You can reset per the vehicle owner's manual, or ask your selling dealer.
Will I damage the car if I don't get the oil changed soon after the light comes on?
As stated in the owner's manual, change oil as soon as possible. It is recommended that oil be changed within 600 miles of the change oil light / message.
Do I have to check my oil level now that my vehicle is equipped with the GM Oil Life Monitor System?
Yes, the system does not sense oil level. As stated in the owner's manual, it is recommended that you check your oil every time you stop for gasoline.
Will I void my warranty if I don't go by the GM Oil Life Monitor System?
Complying with the owner's manual recommendations will maintain the warranty.
I had my oil changed recently and now my GM Oil Life Monitor System light came on.
If the system was not reset (refer to owner's manual) at the time of oil change, the system can be reset as long as it's been less than 500 miles since the last oil change. If this mileage has been exceeded, change the oil at 3000 miles and reset system.
I prefer to have my oil changed still around 3,500 miles, what should I do?
It is ok to change oil prior to being notified by the vehicle. Be sure the system is reset even if the GM Oil Life Monitor System light has not illuminated.
My oil seems dirty, I have 6,000 miles and no light, do I have a problem?
Discoloration will take place under normal conditions depending on driving conditions. Refer to the Owner’s Manual for further information
Can any dealer other than my selling dealer perform Simplified Maintenance
services?
While we like to recommend the selling dealer, any GM Goodwrench dealership can perform the Maintenance I and Maintenance II service and reset the GM Oil Life System.
I use synthetic oil, should I expect to get more miles before the trigger point with GMOLS?
The GM Oil Life System is calculated based on the factory fill requirement. While some benefits may exist, the oil drain interval is not extended due to the use of synthetic oil.
During Summer I drive my vehicle in a very hot climate, do I need to change oil more often?
The beauty of the GM Oil Life System is that it calculates for severe climate use and determines the oil change interval just as it does for trailer towing as well as stop and go operation. There is no need to adjust the oil change based on climate, as well as vehicle use.
I continue to get 3,000 mile follow-up mailers from my dealer, what should I do?
Inform you servicing dealer that you prefer to go by the Maintenance I and Maintenance II driven by the GM Oil Life Monitor System so that they may adjust the way you receive follow-up mailings.
I have another GM vehicle a 2002 model with the GM Oil Life Monitor System, can I use the Simplified Maintenance Schedule with it also?
While it is equipped with the GM Oil Life Monitor System, Maintenance I and
Maintenance II was not yet introduced. The proper recommendation would always be to follow the owner’s manual.
Old Dec 10, 2011 | 02:02 PM
wfturner's Avatar
I am comfortable changing at about 6 thousand to 75 hundred miles, I usually change oil when it is convenient for me and not wait until it chimes
