Off roading supplies?
#21
RE: Off roading supplies?
Looks like you all covered most everything. All I would add is a good shovel, and a Hi-Lift Jack. Hi-Lift is not only handy for changing a tire, but it can be configured to pull you out of mud or whatever you may be stuck in/on.
#22
good call on the shovel, mine's come in handy quite a few times. not many places on a H2 or H3 to put a hilift without tearing off the plastic, so if you go that route i'd suggest something that will hook into a tow loop and then to the hilift, i think they make something like that. i know they make a tire harnessthat goes on the hilift.
#23
I had one set of tires on my K5 that I would take down to 8 PSI. Takes a lot to pop a bead when you mount 12.5" wide tires on a 7" wide wheel.
Here's a nice little web page explaining airing down. http://www.4x4now.com/sfjun96.htm
#24
ORIGINAL: Trey124
If you go under 18 psi you run the risk of the tire coming off the rim, unless you got bead lockers on it.
CruisinCarAudio
12-21-2005 03:18 AM
