Odometer stopped working
Old Jan 23, 2014 | 06:07 AM
motley1987's Avatar
Default Odometer stopped working
The odometer on my used H3 just stopped working. When I test drove it last week it was moving fine but I noticed that the TPMS light was on. I figured it was either b/c the temp was low so the pressure went down or since there were 20" wheels on it, maybe the guy didn't put the sensors in or the system wasn't reprogrammed for the new tire pressure. When I picked it up the TPMS light was off but I noticed after a couple hours that the mileage wasn't changing. If there were no sensors in the wheels and the dealer did something to get the TPMS light to stay off, could this have caused the odometer to stop? If not, what else could have caused it? The display is working and there is a number there, it's just not changing. Thanks for any info.
Ben
Old Jan 23, 2014 | 09:21 AM
happythree's Avatar
speedo work?, like how fast?
tpms not part of speedo odo.
Old Jan 23, 2014 | 11:55 AM
motley1987's Avatar
Speedometer works. Didn't think the tpms were related to the odometer, but figured I'd give it a shot. Have a call in to the service department now.
Old Jan 23, 2014 | 12:37 PM
happythree's Avatar
actually a dead odometer is like a free extended warrantee!
a lot of guys would love it.
Old Apr 20, 2014 | 02:05 AM
midnightgravity's Avatar
Would a dead odometer mess with the operation of the drive? Like for example a bad o2 sensor.
Old Apr 20, 2014 | 03:38 PM
rsc's Avatar
rsc
If the dash/odometer were changed out for a new one that had higher miles than the one that came out the miles would not change until the vehicle catches up with the new odometer's mileage. Dunno why I remember that or from where tho...
Old Apr 20, 2014 | 11:54 PM
Incorrect, all of the Odometer information is stored and relayed to the DIC from the BCM. Swap out a cluster and the DIC will receive the correct mileage for the current rig regardless of what mileage was on the replacement cluster from a previous rig.
Old Apr 21, 2014 | 08:04 AM
happythree's Avatar
the op said the mileage didnt change. didnt say if it stayed where it was,or is now zero?
so the dic could be ok and info not getting there from bcm?. or bad wires?
changing the cluster is a big job, might not fix it.
will a scan tool show the mileage?, changing?, in the bcm?.
Old Apr 21, 2014 | 12:29 PM
rsc's Avatar
rsc
You are correct, I had to te-read the tech bulletin. The H3's and Colorado/Canyon store it in the IBCM, the H2's use the IPC along with the Tahoe/Yukon. Dang "Old-Timers" syndrome again.
Old Jun 11, 2014 | 07:59 AM
oqni's Avatar
Hello.
I have the same problem. My odometer stopped. Speedometer works. What is the solution to this problem?
