ODB-II
RE: ODB-II
I guess I Should have explained myselft.
I installed a in-dash CarPc. I would like to connect to the ODB connection in order to get the same features as in the attached picture.
I only have USB inputs in my CarPC. So my questions are:
1. Where is the H3 ODB-II conection located?
2.How do I get my CarPC connected to the ODB-II connection ?
[IMG]local://upfiles/3019/EC95DAF84E2B49F5815FB7219423113E.jpg[/IMG]
RE: ODB-II
1) The OBD-II conector is under the front edge of the driver dash directly above the clutch pedal.
2) You'll need an OBD-II scanner to attach it to the PC. There are many diferent types avalable. Look for one that has the wires for the OBD-II plug seprate from the box that is in the line. Otherwise you have the box sticking out where the plug is (I'm not sure if I understand what I said there). Look at a few diferent types nd you'll see what I'm saying. The scan tool will have either a serial port or USB plug that will plug in to the PC.
..... was going to give you a link to the OBD forum at carmp3.com, but I see you've lready found it.
RE: ODB-II
Thanks Steve#1,
It looks like I'll order this one:
http://www.obdpros.com/product_info.php?products_id=133
It even has the cables as you described
RE: ODB-II
I had a thread here at hummerforums describing the system, but I can not seem to find it.
So her eis the post I've published at mp3car.com:
http://www.mp3car.com/vbulletin/show...naly-done.html
RE: ODB-II
ORIGINAL: haiminger
Do you build rocket in your spare time or what?
