Is this normal?
Is this normal?
So i just recently purchased a 07 H3 i really like it but having some strange issues i tried hooking a obd scanner to it and when i do all the guages and all the power to the cluster seems to shut off guages go to 0 no illuminated lights and i cannot seem to get my scanner to actually connect to the vehicle . When i unplug the scanner power resumes to guages and dash etc has anyone else had this problem?
NO, what you describe is not normal.
I have a scan gauge II plugged in at all times, everything works.
Try a different scanner, or try the scanner you have on another vehicle to see if it does the same thing then you will know the scanner is the issue.
RealJeep
30
07-01-2011 09:24 AM
FloridaFeMan
02-08-2010 10:51 AM
