Newbie 06 H3 with blown engine
Jumped in full go. Not surprising if you know me.
Facts: Got a great deal (I think) on 2006 H3 with 130k miles; - Interior like new; - Blown engine; - Bought a 64k mile used engine from sw engines (3 year 36k mile warranty) i'm installing now; - installing new exhaust manifold (small crack); -new timing chain and gears (not really needed but why not since it had 130k on it ???); - peeling chrome on 16" tires (Ohio weather i guess??) - Should I use Mobile 1 oil??? Synthetic??? - Corroded gas cap door too ughhh. whole thing Also---what else am I in for with a used 3.5 engine with 64k ? Go the car all apart now? What would you do if you were me ? :) :cool: Your help and experience are greatly appreciated. Thanks in advance. MC - |
Drain EVERY fluid and replace with high quality fluids. Trans, brakes, diffs, Tcase, steering, coolant, etc.
I run Mobil1 synthetic in everything I own. It's your choice. |
Thanks Tainter.Mobile 1 synthetic it is.
SW Engines said I have to change the oil at 1000 miles, then a normal schedule whatever that is 3k miles I guess to keep the warranty. Am I ok with the 3.5 engine or will I regret this? Any other mechanical fixes or "preventative maintenance" I should do. It's got 130k with this used 64k engine. thx for your time. MC |
oh yea---
What high quality fluids. Trans, brakes, diffs, Tcase, steering, coolant, etc.do you use? Learning from experience here i'm hoping. thx |
Originally Posted by OhioHummerH3
(Post 329141)
oh yea---
What high quality fluids. Trans, brakes, diffs, Tcase, steering, coolant, etc.do you use? Learning from experience here i'm hoping. thx Transmission Fluid= Dex 6 Diffs= 75W90 Full synthetic with LS additive Mobile 1 Tcase= I'll let someone else answer because I've seen plenty of arguements on this. Steering= Haven't touched mine.. No issues whatsoever with mine so why mess with it. Coolant= Stick with DexCool. Switching from that to the green can cause sludge and buildup. I have a 2006 Adventure/Luxury model with 74k miles. The scary stories about this year are accurate.. I've encountered most of them. O-H... :cool: |
(Post 329140)
SW Engines said I have to change the oil at 1000 miles, then a normal schedule whatever that is 3k miles I guess to keep the warranty. Am I ok with the 3.5 engine or will I regret this? Any other mechanical fixes or "preventative maintenance" I should do. It's got 130k with this used 64k engine. thx for your time. MC Might want to look at what the GM OLMS is. If you bought a 64K used motor, explain why you are changing the timing chain & gears??? Maybe I don't understand what you bought. Did you buy the complete motor, or a short block? |
https://www.hummerforums.com/forum/i...tons/quote.gif 140k miles/Old gears were rough. I own the shop so I put a new chain on too. |
Engine replacement update:
All went well except my mechanic used old exhaust manifold bolts and the upper bolt near firewall broke. Trying to figure out why A/C isnt working as well. |
| All times are GMT -5. The time now is 07:38 AM. |
