New owner 2007 Hummer H3 - parts needed
Old Oct 31, 2024 | 10:59 AM
Larry T's Avatar
Default New owner 2007 Hummer H3 - parts needed
Hello,
I am a new owner 2007 Hummer H3 Luxury and am looking for some help sourcing some parts ... first thanks for having me and have been lurking these forums before my purchase ... I am looking for the plastic cover on the driver seat floor mount left side ... I just put in all weather mats and noticed it is missing.
Also I am looking for a passenger side illuminated switch ... I have one but it lights up orange ... from the research I have done this is one from a Canyon or Colorado and not the green illumination needed for my Hummer ... I do have the correct bulb with the blue condom so i know it is not the light source that is tainted
One more thing ... has anyone found a bolt cover for the drivers / passengers bolt heads that are by your feet ? I am looking to cover those and wondering if anyone knows the size or has figured our a solution / cover
Thanks again
Old Oct 31, 2024 | 11:29 AM
Welcome to HF. Congrats on the 07.
Your right side seat trim (its a Lux so that means power leather correct) is a discontinued part. GM 15254771. You might find a NOS somewhere, but may have to go used. What happens is some fat azz sits on the edge of the seat getting in/out and breaks the trim clips, causes the seat heater to come on whenever it gets bumped, so your prior owner probably pitched it. There are some posts here about adding a screw to anchor the panel when that happens.
Got no idea about the light bulb thing, not important to me.
If you are talking about the front seat anchor bolts, there is no part to cover them, that is the way they came. Maybe somebody somewhere makes a generic cover but I've never seen one.
Old Oct 31, 2024 | 11:33 AM
Larry T's Avatar
Thank you ... I will try a bone yard .. I thought someone may have aline on a good used source ... as far as the illuminated switch I was hoping someone again had a source to source the proper one for purchase
Old Oct 31, 2024 | 11:35 AM
Larry T's Avatar
It is not that part but the cover for the arm on the back of the driver seat ... it is plastic as well ... I have 3 of them but am missing the one on the outside arm on the drivers seat behind the part number you mentioned
Old Oct 31, 2024 | 11:37 AM
Originally Posted by Larry T
Thank you ... as far as the illuminated switch I was hoping someone again had a source to source the proper one for purchase
There are threads on that with links to Amazon etc. Might be older links, but the info should help.
Ebay has about everything sooner or later it come across. Local pick n pulls can have stuff too.
Larry T's Avatar
Does anyone know the size of the bolt head and maybe i can source a cover elsewhere
Old Oct 31, 2024 | 11:39 AM
Larry T's Avatar
Doc , do you happen to have the part number for the piece i am looking for?
Old Oct 31, 2024 | 11:44 AM
Oh, you are looking for the seat feat cover, right rear. Just google it or do a GM online parts search.
Good luck.
Old Nov 3, 2024 | 08:34 PM
NMH3's Avatar
Here's a great online source for the illustrated parts catalog for the H3: https://webautocats.com/epc/hummer/
Here's the drawing for your 07 H3. I believe the part you are looking for is item 16, the driver's seat outer cover PN 25906911, which is discontinued. It was also used on the GMC Canyon and the Chevy Colorado from 2004-2012 so you might be able to find one at a local pick n pull. Or, just don't sit back there and you won't ever notice its missing.
Old Nov 7, 2024 | 02:10 PM
Larry T's Avatar
Thank you ... that is a great resource
