needing advise on bars
Old 04-29-2009, 09:32 PM
kidstuff's Avatar
Default needing advise on bars
i want to get some nerf bars but i see some that i do not like at all. they hang down too far or out too far. do you know of the best ones for a tighter fit?
Old 04-29-2009, 09:36 PM
DAGKANA's Avatar
be more specific... color? tube or square? there's alot of options out there... only you can decide what you truely want on your rig.
-Dan
Old 04-29-2009, 09:45 PM
Circuitguy's Avatar
There are many brands available but most are copys of each other or the oem style step bar. I do suggest to stay away from the "universal" cheaper bars as they tend not to fit correctly and can be a bear to install. Brand name are always a same bet, Aries, Steelcraft even the factory GM brand bars just to name a few. If the price is too low then it could be too good to be true. As Dan said its all up to you and your taste of style. Good luck!
Old 04-29-2009, 09:50 PM
kidstuff's Avatar
yeah im thinkin oval stainless
Old 04-30-2009, 01:10 AM
JGBB04's Avatar
If you plan on wheelin alot but still want steps I would go w/ the factory rock rails & the removable steps. I was going to do this but found out they don't make factory rock rails for the T
Old 04-30-2009, 05:29 AM
Gunner_45's Avatar
These are very nice if you are not a hard core, on the rocks wheeler....
http://www.n-fab.com/products/search...7/productID/95
04-09 Hummer H3 Wheel to Wheel
Part #: H0464
H3 4 Door (frame mount) direct bolt 2" main tube
standard color is textured black
Features
-Fichter Designs licensed to N-FAB, Inc. are Protected U.S. Patent Law and International Copy Right Law. U.S. Patent # 6588783, # 6874801 and # 7416202 other patents and continuances pending. (see policies section of site for more information).
-Made In The USA!
-Standard Color Is Gloss Black Powder Coat
-Life Time Warranty on Product & 5 Year Warranty on Finish
-N-FAB Patented Drop Step Design
-465 Lbs. Weight Rating
-Solid 1 Piece Construction (Non Modular Design)
-Main Bar Protects Truck From Road Debris
-Bar Is Positioned High & Tight For A Better Fit & Cleaner Look
-All Bolt On Design That Wont Flex
-.084 Wall Tubing With Black Powder Coat Finish (Custom Color Available For An Additional Charge)
-Main Bar Extends From Tire to Tire
-Wheel to Wheel Nerf-Step
Old 04-30-2009, 07:37 AM
If you go in and it is all guys, and one of them has chaps on with a thong, it's probably a gay bar?
Horse walks into a bar..........
Bartender: so bub, why the long face?
Bada boom, pish.
Old 04-30-2009, 05:47 PM
Gunner_45's Avatar
Damn Doc..........I had to shake my head on that one.......Great googley moogley.....
Heated Heavy
01-30-2010 04:17 PM
jus_humm_it
11-30-2009 07:37 AM
SMITTY865
11-08-2009 01:21 PM
yellowjacket19
08-18-2008 01:04 PM
H1Intercept
07-17-2008 04:02 PM
Quick Reply: needing advise on bars
