Need a little help with a power mirror issue
Hey guys, new to the site, but I have a problem. I picked up an 06 H3 last week and learned after purchasing the truck I having an issue with my power mirrors, specifically the passenger side mirror.
When I use the power mirror adjustment (switch) on the driver door handle to move the passenger mirror it works fine moving the mirror into, up and down but when you go to move the mirror out it dims the interior light and will blow fuse #56 if held for more than a second. Now the driver mirror. Moving the driver mirror in all directions, everything works with no dimming issues but when I move the driver mirror out the passenger mirror will move in at the same time. Need less to say I am lost and any insight would be appreciated. |
get the wiring info and pull the switch assm out and maybe pull the door trim. it sounds like wires got pinched and one is shorted to ground blowing the fuse. typically a short to ground is a fuse blower. it could be all in the dr. door
| All times are GMT -5. The time now is 02:44 AM. |
