My daystar body lift install with a couple pics
Old Jan 31, 2011 | 01:34 PM
jake1z's Avatar
Default My daystar body lift install with a couple pics
Half way through and taking a break... Took me 35 mins to install the drivers side and to knock the bushing off the passenger side bolts... The biggest pain in the *** so far has been the bushings. They are mounted on the stock bolts and held in place by grooves etched into the bolt.... I had to put them in a vise and beat on them with a flat head and a rubber mallet... Other then that its been cake, jack the body up with a piece of wood and slide the pucks in... Zero problems so far... Body gap is minimal on the one side... Heres a couple pics for now, i will take some finished ones in a little while. Still need to mod the fan shroud too but shouldnt be too big of a deal.
this shows the grooves in the bolt that are ment to keep the bushing on the bolt. pita to get off...Name:  54cb4eb0.jpg
using the vice to hold the bolt while i hammered off the bushing
one of the pucks mounted in place...
Heres some completed pics... currently in the process of raising the side steps... which means only two bolts holding the steps instead of 4.. i never use the steps but my wife does.. ill have to see how they hold up...
body gap rear
gap in front
none on the rear wheel wells
side steps at stock hight will post pics when i bring them up higher
Old Jan 31, 2011 | 04:00 PM
xllkoyokollx's Avatar
Looking really good. Can't wait to see the finished product. Your right the body gap really isn't that bad.
Old Jan 31, 2011 | 04:09 PM
Mr. Fancy Pants's Avatar
I bet your steps are perfect height now as they are useless at normal height. How much did the kit cost?
Old Feb 1, 2011 | 01:04 AM
Bullwheel's Avatar
Would be great to get better photos after you finished...?!
Especially the gap in the front....there is the rubber seal/ lip to close the gap between bumper and grille....is it too short after....is there a replacement....?
Thanks for posting the photos and giving us some great help for our next decission...
Old Feb 1, 2011 | 11:22 AM
jake1z's Avatar
Bought the kit on ebay from top gun customs for 199 shipped, i made an offer on there auction and they accepted it... I need to find the battery charger for my regular camera.. Heres another shot with the i phone of the front gap, the raised side step and my newly mounted hella 550s for the hell of it... i dont ever use the steps i only keep them on to stop peoples doors in the parking lot. The gap in the front is not even noticable unless your looking for it... if you dont own an h3 you would never know the truck has a body lift on it..
Old Feb 1, 2011 | 11:45 AM
drtom's Avatar
Banned
ahh??,what did i miss,? the reason for this ezercize?
just curious
Old Feb 1, 2011 | 12:12 PM
jake1z's Avatar
Im just saying if you dont know the lines of an h3 you would never know it has the body lift aka the change is so minimal that you can barely tell.... heres a couple pics i just found my camera....
Old Feb 1, 2011 | 02:03 PM
Good pix on the gaps.
Jake, can I ask why you did a body lift?
Old Feb 1, 2011 | 03:06 PM
jake1z's Avatar
Well ive been looking to upgrade my tires, i wanna go with 35s but i still want to have plenty of wheel gap. Ive put body lifts on the wrangler and dodge ram that i used to own so i knew it was pretty simple. And the price was pretty cheap at 200 bucks...
Old Feb 2, 2011 | 07:17 AM
dafihummer's Avatar
why is your exhaust exiting on the right and mine on the left ?
