My 2006 has a bad steering shaft!! ( and more )
Old 08-08-2007, 03:38 PM
mfish's Avatar
Default My 2006 has a bad steering shaft!! ( and more )
I took my H3 to the dealer today for a knocking noise coming from the front of my truck. The symptoms sounded similiar to the steering shaft problem but from what I have heard and read it only affected 07's, and Ihardly feltit in the pedals or steering wheel, I did feel it on the floor and so did my passengers.
Well...my steering shaft is the problem, and mine is an 06, made 10/05.
So..all you 06's out there watch out!!
Of course the new part ison backorder[:@]
Update:
It turns out that the front crossmember was also loose, they re-torqued it.
Old 08-08-2007, 06:56 PM
Default RE: My 2006 has a bad steering shaft!!
lol I had that fixed on my 06 sierra and i also know it is affecting escalades. The believe the problem is actually the way it is greased but they replace the whole shaft. I have seen boxes full of shafts that have been taken off.
Old 08-08-2007, 08:24 PM
H3X442's Avatar
I work for a cadillac hummer dealer (shop forman). I have just started to see this problem on the 07's and have never done one on a 06 yet. There is a tsb on this concern. Steve
Old 08-08-2007, 08:33 PM
mfish's Avatar
ORIGINAL: H3X442
Well strip my gears and call me shiftless!!![sm=gears.gif]
I also thought it was only 07's...I hope they know what they are doing. I havent done much driving since they retightened the front crossmember to see if the problem is totally gone or if there is still some knocking from the steering shaft. If I don't hear it anymore I may not take it in when they get the new shaft.
Old 08-09-2007, 06:10 PM
mfish's Avatar
Default RE: My 2006 has a bad steering shaft!! ( and more )
After driving some more today the knocking I was hearing is still there so I guess it must be the steering shaft. There is less knocking due to them tightening the crossmember but I can still hear and feel some knocks. So.... I guess 06's aren't immune to this problem.
Old 08-14-2007, 04:49 PM
iflyswa's Avatar
I had mine replaced on my '06 H3, much better now. Still knocks *slightly* and not very often, but i'm kewl with it until it gets worse.
Old 12-07-2010, 12:02 PM
bigdog100's Avatar
Is this problem a recall, because I am out of warranty?
HumminNBoatin
04-24-2008 03:10 PM
solarflare
04-21-2008 08:01 PM
hummerbee
17
09-09-2007 07:55 PM
RealJeep
08-24-2007 10:46 PM
shortbus
07-21-2006 12:12 PM
Quick Reply: My 2006 has a bad steering shaft!! ( and more )
