Key Fob/DIC Problem
Old 06-01-2007, 02:57 AM
Default RE: Key Fob/DIC Problem
Ya Gots GrEmLiNs!!!
Old 06-01-2007, 04:25 AM
f5fstop's Avatar
Does it always NOT work in certain areas, while working most other places?
Old 06-01-2007, 01:01 PM
ORIGINAL: ultimatesecurity
I am having the same issue with my 07, H3. Just got back from the dealer today and they took a look at it. Told me everything was just fine and that the tech just reprogramed it. Than they showed me some crap about interference and they thought my amateur radio equipment was interfering with it. I told them it did not and that it had problems even before I installed my radio.
At the dealership the keyfob worked fine.BUT after i drove off and tried locking it again at another parking lot, the vehicle would not respond at all. BOTH KEYFOBS! I had to manually lock it. When I returned two hours later it opened with the keyfob. I don't understand.
Ironic with a name like you use...
You've seen me say it before...Disconnect the battery cables negitive first, then touch them together for about 30 seconds, then re-connect in reverse order...This may or may not work, but it won't hurt to try it.
Old 06-01-2007, 08:35 PM
Ya Gots GrEmLiNs!!!
_____________________________
[sm=funnypostabove.gif]
Old 06-01-2007, 10:35 PM
finseeker's Avatar
I just bought an 2007 H3 three days ago, (what a sweet ride) and have already had a problem with key fob, but only in one particular spot. It hasbeen working fineevery where except when I went and visited my girlfriend at her work. I parked in the same spot three different time and it would not work, but worked everywere else. I'am thinking it must be some kind of interference, there are neon lights around and a cellphone store I don't know its just really wierd.
Old 06-02-2007, 05:55 AM
ORIGINAL: finseeker
The little corner of the world I work in is kinda like that.. Other remotes I've had on various vehicles won't respond at all around here and the H3's has very limited range.. Of course you can stand outside our front door and count no less than 8 high mast radio antennas.. LOTS of RF around here...
Old 06-02-2007, 03:16 PM
bigjdhoss's Avatar
I had this problem once when I parked in an underground parking garage. Ever since then, it's work ok without any other issues.
Old 06-02-2007, 05:18 PM
Add another H3 owner to this issue list. The service advisor swapped the battery, then the rubber keypad part and it has still acted up (albeit less).
Sounds like a widespread problem...
GOFASTER
01-14-2010 11:54 PM
GOFASTER
11-07-2009 09:14 PM
cryscor
04-11-2009 12:38 PM
jrbnc
02-21-2009 08:18 PM
finall
12-20-2008 11:30 PM
Quick Reply: Key Fob/DIC Problem
