key dont work in door
Old 05-25-2017, 01:45 AM
happythree's Avatar
Default key dont work in door
last week i checked it and it was stuck,no unlock. i lubed it and it freed up. i added a good light weight lube oil. it was smooth.
today its stuck again??
wonder why?
Old 05-25-2017, 08:04 AM
wonder why?
Interesting..... what lube oil did you use? Hope it was not WD-40?
Is the key original?
I have only used my door key in the door maybe 4 times in 10+ years, mine is probably dry, and the key worn from the ignition. Maybe they do not quite mate correctly anymore???
Old 05-25-2017, 10:32 AM
happythree's Avatar
light weight penetrating/lube, good stuff. key is same as last time. ill try others today. i hate to pull it! even though i air chizeled an opening when i put it in a new door 2-3 yrs ago.
dont use wd40 much...
i forget if those pins are up or down for lube to get in. i had a jeep lock that was up. didnt lube till i pulled it?
Old 05-25-2017, 03:13 PM
happythree's Avatar
Default key!
i pulled out my hidden key, from ace hdwe,6 yrs ago, not used. it works fine. u were right doc.
also forgot another ,,,in my wallet. old age...
Chance Koke
06-05-2019 05:10 PM
chazyrae94
01-06-2012 02:47 PM
mnext02
09-26-2011 10:45 AM
amstaffbair
01-02-2009 04:22 PM
importkiller
10-16-2006 11:47 AM
Quick Reply: key dont work in door
