Jetchips MAF Sensor
Jetchips MAF Sensor
Has anyone tried a the jet Mass Air Flow Sensor yet? I was thinking of getting the Jet stage2 chip + the MAF sensor + the Jet TBS. I have a Flowmaster muffler and True Flow intake. I would just like this I5 to put out a little more power.
I have not. The MAF on the 3 is built into the airfilter box outlet, so changing the MAF in and of itself is really just a change in voltage sent to the PCM, and altered by their "chip". You would be better off with a PCM tune and get the results direct, rather than "tricking" the PCM into thinking input variable are different than they actually are.
On an H2 (and some other GM V8s) changing the MAF can increase air flow because of the shape of the MAF "ring", not so with the 3.
Good luck if you go for it and let us know what you think if you do.
Alex2012
18
03-06-2014 06:51 AM
C31322
09-11-2013 03:27 PM
Kimmea
08-01-2012 07:47 PM
